Oh yea I forgot about that light. This optic is going to be waaaayyyy better than the E01 optic. The E01 optic creates a lot of artifacts. The beam on this new light looks much cleaner and more focused.
Interesting... I assume you are judging the beam from the posted vid? It does look pretty good compared to my E01. I flashed the E01 with Anduril2
So between an improved optic and better throwy LED, should do wayy better than an E01 - I measured 32 kcd on the stock E01 on a 30T cell, which is probably close to blowing/blueing a SST-40.
Yea judging from the video. The E01 was the only FF light that I didn’t like. This light however looks amazing
That’s quite large if this head is similiar to the ec01. I wish they made this light the same size as the nano gt but with the 16340 cell.
We’re talking about the E01 not EC01
I make fast comparison with T1R (left) and GT nano (right)
Led: same CULNM1TG
Lumens: 1000 vs 450
Candelas: 125000 vs 23400
Thorow: 700m vs 300m
Battery: 22430/18350 vs 10180
UI: Anduril 2 vs Narsil
Size: 79 x 37 x 26.5mm vs 24 x 52.5mm (head size much bigger)
Dirver: 6A buck vs 2.5A TA FET
Charging: 2A USBC vs (no detail but can charge)
Weight: 78g vs 17g
The gt nano is much smaller but T1R should last much longer and brighter.
This light is much closer in size to the GT Micro. Micro is 36 mm head x 105 mm length.
Wouldn’t a 16340 cell offer completely rubbiush runtimes though. So much so that it would make a high output or long distance light pointless with such a power plant.
Jack confirmed this light will be released next week. Also that the T1R will be available in Red, Green, Blue and black anodized color options.
I wasn’t too excited about this light at first, but seeing the size of the T9R, now I want to see it’s price to see it’s it’s worth being my first mini-thrower. Hopefully it’s in the KR1 price-range so it becomes a no-brainer.
Update: 2021/1/17
Fireflies T1R pocket thrower will be ready for sale on 25th.
Specifications
LED - Osram CULNM1.TG
Body color : Matt Black / Army Green / Deep Blue / Deep Red
with 4x RGB auxiliary LEDs
Max brightness: 850 lumens , 125 000cd
Max Beam distance: 780 meters
3.6-degree beam angle TIR Optic , Efficiency 146cd / LM
Ultra-clear AR coated optical glass lens
Durable electronic side switch
High efficiency 6A constant current buck driver (>90% efficiency)
True 2A USB-C in-built smart battery charging capability
with Heavy duty Removeable Magnet
with Stainless steel Clip
1x Fireflies 22430 2000mAh lithium battery (Included), or 21700 battery with extension body.
Operating range 2.7V to 4.3V
Dimensions
○ Head Diameter - 36mm
○ Body Diameter - 26.5mm
○ Length - 87mm
○ Weight - Approx. 105g
I am happy to finally see some production pictures and I like the green but I think the red and blue are a bit too ‘bright’! May I know what it is the cost? I like the size and I think it is ideal match for small led with small flashlight. You have interesting battery choice of 22430 but unfortunately it is uncommon to buy. The optic look like a special double reflection optic, can you please share more information? Very interested to see some review soon!
Price range?
Thank you
Could not figure out yet, if I actually need these, but they are lovely to look at (TIR optic is also a big plus).
The TIR optic and multiple battery tubes makes this one a buy for me.
Are you sure that driving the emitter that hard (6A) makes sense?
[image] KW CULNM1.TG is 4.0x4.0mm version of KW CSLNM1.TG (or 1mm2 version of Oslon boost HX), with lower thermal resistance, I tested two 5Q bin samples under same conditions (fan cooled heatsink), results: [image] So we got the first white LED that broke 1000lm/mm2 barrier (by a decent margin in case of higher performing sample)[image] What can be seen from numbers is two samples are within 5Q bin rating (710 - 800lm@3A), but one is at bottom and other is closer to upper level. 5Q bin i…
Because as you can see above, even with much better cooling the brightness is almost flat between 5,5A and 7A. Going down to 5,5 or 5,3A would net pretty much the same brightness and throw while using 15% less energy (longer battery life, less heat etc).
LED4Power tested the 5Q flux bin. FF was able to procure the higher 6Q flux bin. Not sure if the 6Q would max out at a higher amp since it hasn’t been tested.
Yes, they’d max out at the same current and a slightly different brightness.
Are these for sale now?
It doesn’t quite look like it yet - All I get is a “Send Inquiry” button:
I’m super excited for mine to arrive though (courtesy of the Old Lumens Challenge prize)
Are the two holes on the tail cap for a pocket clip? Does the light include it? I hope so.
Does the 21700 tube come with the light? I have the fireflies eo1 osram and it’s a tiny bit smaller head… 2 mm. And the eo1 does not come close to the 125kcd that this new t1r supposedly does. Maybe only 35kcd. Good job if these numbers are accurate.
