UPDATE: Hello Frontier Fiber! [Goodbye Viasat satellite internet. Goodbye Starlink internet!]
Check out r/cordcutters on Reddit if you are looking for options. You might look into 4g if you have good cell signal.
We use a lot of data.
We need a plan that has no data caps.
Is that even legal? New law last week, kinda related but not exactly, ISPs can’t charge a equipment fee if you don’t use their equipment. Pretty obvious, right? Everything needs to be spelled out nowadays.
Found this with quick google:
“The FCC’s rules are clear: cable companies must let customers use their own equipment (including modems) unless it isn’t compatible with the network or unless it would cause some kind of harm or was designed to let customers obtain services they didn’t pay for.”
I'm not saying that it's legal.
I'm just saying that with Viasat, they have to provide your modem/router, and you cannot get it from anywhere else.
Your account information is stored in their equipment and will only work with your account.
Another google found this
“Can I use my own router with Viasat?
Yes. You can use your own, or get the new Viasat WiFi Modem or Gateway with built-in Wi-Fi when you order Viasat Internet service. If you don’t have the Viasat WiFi Modem/Gateway or would prefer to use a different router, any modern router will work with Viasat Internet service”
They provide a 2-in-1 modem/router.
You can use your own router, if you want, by not using their router, but you have to use their modem.
Our router doesn't work very well with their modem, so we use both their modem/router.
Try this read
How much for a new Viasat unit?
Can I use my own modem with Viasat?
You can use your own, or get the new Viasat WiFi Modem or Gateway with built-in Wi-Fi when you order Viasat Internet service. If you don’t have the Viasat WiFi Modem/Gateway or would prefer to use a different router, any modern router will work with Viasat Internet service.
The router that Viasat provides works fine.
It's the modem that doesn't work, and you have to use their modem.
Sounds like they should make it work if it doesn’t. If service isn’t at the curb, it usually isn’t economically feasible to extend service to your house. Stuck with what you have.
They should, and maybe they will on Wednesday.
If not, maybe we'll try HughesNet.
Good luck and I hope they show. Utilities are a pain in good times and now Covid has made it worse.
Hughes net isn’t any better. My mon and aunt that live up the road have it, just out of reach of the telco’s broadband. They do nothing but complain about the slow and intermittent service.
Will Viasat just send you the modem you need instead of waiting for a service tech? Anytime I have had problems with my ISP, they have just UPS’d me the part and I would install it and call them on the phone for final configuration. Hard to imagine them not doing something about your problem.
Nope.
You have to make a service appointment, and they have to determine that the modem/router is on its way out before they'll replace it.
They will not send a modem/router in the mail or via UPS, etc.
My only experience with ViaSat is using wifi onboard airplanes… many frustrating flights.
Gogo, which I’m using now as I type this is not perfect, but much better.
Can you not get 5g internet router
Verizon or a t+t or even T-Mobile do some packages in USA
Like I said before, we use a lot of data.
If you know of a plan without a data cap, I'm all ears.
I think 5G plans have no data caps
most the 5g internets are uncapped that ive been seeing
verizon
starry internet
Not available here yet. Maybe by you RC.
Sounds good, though Verizon 5G is only in a handful of cities, and is not in Palm Desert.
