I emailed Hank on Dec 6 asking about the cyan and he said, “ The cyan D4S V2 will be back by next month.”
green and cyan are the colors that always sells out… not sure if he really willl bring those back ? is sad
It is sad… I have seen enough interest on BLF for it to seem worthwhile for him to bring back the colors for D4s V2… unless he is planning something else to fill that spot. I would be happy either way
mortuus: Artiet59:I have been waiting since april ( i got into this hobby, technically high output lights, in january) to see the D4sv2 in green again. I have a gray sst20, almost bought the w2 recently as i have the d4v2 w2 from hank and its awesome, and the d4sv2 is still one of my favorite lights. i have meailed hank a couple times about bringing back the green body d4sv2, and he said it wouldnt happen. im shocked to see the above comments that it is coming back.
A copper one would be tasty too…
I was perfectly fine with the Emisar Gray, a very good body color - but I would also welcome Green.
Copper would be AMAZING
Copper would be AMAZING HEAVY (potentially good too)
Heavy would be awesome! Lol
true but copper is not for everyone… still odd no color for basic d4s…
well i would hope he wouldn’t ONLY release a copper version lol. Im hoping for green ano really, not in my budget right now to pay the extra for copper. that is usually my biggest reason for not buying copper. anyway, we will see…
richbuff: polarweis: richbuff:I am very happy that I got mine, not green. White. W2. Turn on 4,020 lumens and 429 meters throw from this size flashlight is a thrill. I guess I should latch onto two more, while supplies last.
Did you have any other d4s before with different led? Sst20 got hot really quick and I was wondering about w2
No; and it gets hot real quick. I use it on turbo just for a few seconds to illuminate an area and quickly identify points of interest, and then I throttle back to normal modes.
I think d4s is pefect light but a single big dye led with reflector has much range and better thermal performance(c8 type).
I would love a single led / reflector d4sv2… I’ll take one with an sbt90. Why not?
Had been saving to pull the trigger on D4V2 with Nichia 219C, but it’s not available for months. I had contacted Hank and he said it (Nichia 219C) was discontinued.
Do you know what the best battery for the d4sv2 is . Is it flattop or button. Is even a button top 26650. Thanks
Shockli 5500mAh 20/30A
I need to know flattop or button top
This one is flat top unprotected.
So you are using flat top batteries. Thank you
Yes, this and Vapcell 26650 5900mAh 20A cont, which is flat top too.
- Thank you for help.
The new Astrolux ea01 is a little bit longer, but essentially the single led version of the Emisar d4s. No aux leds though, but does have lighted switch. I have both and they are awesome!
