FREEME ✌ ASTROLUX WP2 LEP 480lm 2300m 21700 Flashlight - $195.99
Only typo I found was on the BG WP1 page - says 25,000 CD, should be 250,000 CD
Interested!
are there beam comparison pictures between the two?
My final price is $210.
interested
Read OP.
Group buy could end as early as Dec 31, 2020.
I’m confused, the two pictures are two different lights?
im assuming the longer and tighter one is wp2, the other is wp1
Looking at the actual photo and the measurements of the item is it just me or is the rated CD seem to be very conservative. Based on its measurements I’m expecting north of 1.5m CD but then again my testing equipment is amateur at best for throwers. :person_facepalming:
I’m interested at around 200, but what’s what? Are both new releases?
Why is there such a huge price jump from the WP1 to the WP2? The difference between the M2S and M1X was only $8.50. Even after the price went up the M1X with M4DMAX coupon still costed less than this. I’m still deciding whether I should go ahead with it. Will the price increase once the groupbuy ends and will there be another groupbuy after that?
well wp2 is 1300 kcd vs wp1 250kcd, but im just curious if the group buy price is higher or lower than mad max deal.
Originally the Jetbeam M1X was $22.24 cheaper than the Astrolux WP2 groupbuy price. It did increase after some months but as far as I remember, it was still slightly cheaper. It’s the same light but with an updated UI (better IMO).
i just looked them up, the spec look almost identical, but theres a few differences.
wp2 has magnetic rotary switch.
wp2 is listed to be 100g heavier, which is quite a lot considering its 360 vs 260.
wp2 is listed to run 480lm for 4.4h while m1x run it for 2.7h
if all this is true, then wp2 seems to be running a more efficient driver, the extra weight might be due to the magnetic rotary switch? cuz the dimension is almost the same, with wp2 body being 2mm wider, but i dont think that would account for the 100g
in if 200.99 and lower
After seeing more I’m in under $210.
The new M1X and WP2 have the exact same dimensions. I don’t think a more efficient would make that much difference to the runtimes. Maybe they just measured it differently. The weight is a bit more than I’d prefer, not really a dealbreaker though.
Forget about other places, Banggood reserves the best price for all our group buy only.
