Nice colors.
Why does a light with low power like this work fine indoors but not adequate outdoors to see where you walk?
Because indoors it’s the only light, and outdoors there are other lights that may disturb your view.
Chance that you are in “night vision” mode is higher than when you just stepped out of your car.
Or: distances indoors are smaller than outdoors (my front yard is bigger than my bedroom)
As an emergency light it is fine outdoors, it will light your way, but a light with more output and a hotspot works nicer.
distance differences call for lumen differences
indoor distances are shorter than some outdoor distances
something at arms reach,
a plate of food while seated at a table,
does not need a lot of lumens…
no matter indoor or outdoor… the key is the distance you want to illuminate
the door handle to the toilet indoors… the zipper pull on a tent door outdoors… the keyhole on the car door… all these things are within hands reach… so the same lumens suffice… no matter indoor or out… its all about the distance
The C01 is a 7 lumen light. As a rule of thumb thats good for distances of 7 feet or less.
I’ve just received this light thinking that it had more than one mode, my bad for not reading before…
I prefer the C01s.
both is better
I prefer the C01 as a close range light, and the C01S as a longer range light.
The C01 beam can show all the food on the plate at the same time, the C01S can only show part of the meal, due to the narrower beam
the C01S can spot a cat 20 feet up a tree,
otoh
the C01 works better to see the cat on my lap
Sorry if this is a stupid question. Do the sofirn c01 Sophia comes without any glass? The led is exposed to open air?
Yes and no. It’s not a “bare” LED with silicone coating or dome. It’s a 5 mm LED with hard plastic housing, sitting in an aluminum “reflector”.
correct, that is normal, no glass lens needed nor available.
the 5mm LED is manufactured with a waterproof optical dome, and installed with an O ring around the base. No water or dirt can get into the electronics.
if you had ever seen a Fenix E01 (which cost more and was not High CRI), it had the same no glass lens. It is a very durable design.
Enjoy!
Thanks Jon and Sammy! I was surprised that there is no glass lense but I don’t think sofirn will forgot the lense there must be something I’m missing. Lol
This is the first kind of light I have with this design. Very interesting.
Confirmed unpotted colors (for modding) are Desert Tan(Brown), Blue and Orange, correct?
yes
NOT potted C01 colors:
brown
blue
orange
YES potted C01 colors:
black
green
red
Great. I’m going for some more.
Just adding to the dataset. Received order from Sofirn website, blue and orange not potted, all other colours potted (didn’t order brown so can’t comment).
There’s some variation in the tint though and unfortunately for me the potted ones look the worst.
Also, the new colours are very nice, the green is lovely, as are the blue and red (now deeper / richer).
What is the best solder league to put on the positive driver contact to protect it from scratch?
In the past I used Sn-Pb 60/40 but after a little use it blackened and had to be cleaned, I thought it was caused by the presence of lead
Buy enough C01 lights, Sari. I’ve used one from the initial batch multiple times a day. Still intact pads.
From djozz:
How to add brass foil on the contacts
Q:
You can also get gold contacts.
https://www.aliexpress.com/item/33040243320.html
pure 24K is probably too soft.
plated Contacts should work better
or this: Gold plated copper
a quick google says, that is not correct,
lead tarnishes to a dull gray color
Tin tarnishes black
When I clean threads on a lamp it is always dark grey smudged.
