wle
(wle)
September 17, 2020, 4:14pm
14
if you are removing the battery and adding wires to measure things, that may be throwing the charging off
also if you stop and restart a cycle (esp when it is finished) that may throw it off also
maybe what it really wants is to
a. start with a discharged cell (somewhat)
b. charge from there to 4.13V
if you restart it already at 4.13, that might throw it off
but it should always be checking for 4.20 and never go over that
if you have extra wires, that may uncalibrate the voltage or current readings it is taking during the cycle.
Muto
(Muto)
December 25, 2020, 5:09pm
15
4.52 volts!
Yikes.
First time I tried to charge in flashlight since I got it.
Purchased Nov 27, 2020
It is going back to Amazon.
I’ll try another one as do like the light.
New stock is supposed to be fixed.
WUBEN
(WUBEN)
December 26, 2020, 7:38am
16
Thank you for your time and effort to run a C3 report. I just found this thread on the comment of my WUBEN C3 30% off deals.
Our tech guys has fixed the overchage issues and sqare spot after getting the feedbacks from customers. Stocks now in Amazon
is the new version C3 that do not has overcharge issues and already update the TIRE to has a round spot.
Links to access: https://amzn.to/38EnK7G
A lighting deal is coming in Dec 26th to save 15% off. Additional coupons might show up too.
d_t_a
(d_t_a)
December 26, 2020, 11:18am
17
That’s good to hear. Would be interested to re-test the Wuben C3, but I’m unable to order from Amazon…
Zappaman
(Zappaman)
December 27, 2020, 3:54am
18
“… the TIRE to has a round spot” What does this mean?
The spill with the previous TIR has a square shape... more like 3 corners and a rounded 4th. The spot is round and nice. I should take a picture. ..
I have a new one inbound for Monday.
Zappaman
(Zappaman)
December 27, 2020, 4:43am
20
Still confused on that comment.
I have a C3 bought about 6 weeks back. Guessing it’s got this over-charge “feature”
I do like the light though (despite the 2600mAh “protected” battery- wass’up with that?). Still a nice throw for it’s small form factor. I’ll just charge via the Zanflare Vs. the internal USB port anyway. Also prolly’ use a Q30 or something a bit more modern battery wise.
I would be too. I posted a picture above so the outer and inner spot IS round and it's just that outer TIR artifact, aka. spill, I think, what some commenters find detracting.
Zappaman
(Zappaman)
December 27, 2020, 5:12am
22
I just pulled mine out and see the “square bottomed” spill as your pic shows… looks like a “flat tire”
— thanks for that effort Nach!
WUBEN
(WUBEN)
December 27, 2020, 5:51am
23
I will suggest to drop an email to support@wubenlight.com to claimed one.
WUBEN
(WUBEN)
December 27, 2020, 5:55am
24
Sorry to make your confused.
The first stocks of C3 has a square spot. But our tech guys has solve this issue by upgrade the TIRE to make the spot round rather than square.
Check Nachtfeuerzeug comment on #19 for more info
Zappaman
(Zappaman)
December 27, 2020, 6:02am
25
OK, I sent an email just now. Are you suggesting I can get a replacement? I own a C5 too (great little light!)
Thanks.
WUBEN
(WUBEN)
December 27, 2020, 6:10am
26
That depends on which verdor you bought from.
This is the shop I charge: https://amzn.to/38EnK7G
Anyoe has bought the first batch C3 from the above link, pls PM me your order number for after- service
Zappaman
(Zappaman)
December 27, 2020, 6:13am
27
Hey great service here! I DID buy from that Amazon shop and am sending you my order # right now!
Thanks Wuben!
WUBEN
(WUBEN)
28
C3 is on lighting deals now for 15% off plus 5% off coupon, total 20% off.
Ended in 13 minutes.
Get a new one now to save big
Link: https://amzn.to/38EnK7G
Unheard
(Unheard)
December 27, 2020, 11:55am
30
Olights i1r2 does the same square spill. I thought that would indicate a good alignment of LED and optics.
Zappaman
(Zappaman)
December 28, 2020, 6:43am
31
Just a shout out here to Wuben for standing behind the MANY great lights they sell. :+1: :+1: :+1:
I personally own a C3 (and smaller C5- 14500) bought this last year. BOTH nicely designed lights with excellent finishes (several colors). The C3 had issues with overcharging (see this post a few months back). It also had a slight misalignment problem with the reflector/led. As I bought the light on Black Friday I figured I (kinda) got what I paid for, BUT when I asked them about it they INSISTED on replacing my C3.
In fact, SEVERAL Wuben reps contacted me to insure I was happy. Very professional, honest, and straight-up about the C3 problem and wanting to make it right.
I was a fan, and now I’m a BIG fan of Wuben… and I can see more of their lights in my future.
d_t_a
(d_t_a)
December 28, 2020, 12:33pm
32
I got the Wuben C3 from Banggood before (which has the overcharging issue, which I am more concerned about).
I also did notice the "flat-tire" beamshot when shining the C3 on a wall, but I think not too noticeable in actual use..
In my Youtube beamshot video below, I made this comment in the description, about the "square-shaped" beam pattern for the Wuben C3:
1) reflector:
Wuben L50S uses SMO reflector
Wuben C3 uses TIR optic
(comment: when at near distances up to around 2 meters or ~8 feet away, on a white flat surface, the C3's beam displays some square beam pattern)
I'll try to make another beamshot of the new Wuben C3, IF I can be assured of getting the new version (I am unable to order from Amazon).
WUBEN
(WUBEN)
December 29, 2020, 1:28am
33
Stocks in www.wubenlight.com is new version C3.
I'm not sure if the bandgood's stock, sorry.
