You'd be able to use the pogo pins as well, there's a pin header on that side as well after all. Just need to manufacture a cable that swaps signals according to the needed pad arrangement.
I'd expect six just loosely held wires to be a quite dodgy connection.
I meant using both sides – the programmer and the pogo pin PCB – and connect them with jumper wires. Or is Hank’s pogo pin adapter just 2+4 instead of “full” 4+4? In that case it can still be used – just omit ground or V+ and connect it directly to the flashlight.
5x AMC7135: 5 * 0.35 A = 1.75 A
1/256 duty cycle: 1.75 A / 256 = 6.8 mA
LED + MCU: 6.8 mA + 2 mA = 8.8 mA
Battery capacity: 4 * 3300 mAh = 13.2 Ah
Estimated runtime: 13.2 Ah / 8.8 mA = 1500 h = 62.5 d
Recently I got my BLF LT1 and it has a spare USB cover together with the spare o-rings. You should ask Sofirn if they can send you one. They should have it available as a spare part.
Do you know which screws (with which dimensions) to buy and that would fit the BLT L1 screw holes ?
I ordered these ones (flavor “LS047” / screw 4.5mm + additional height 3mm), and sadly they don’t fit well (and not in the same way between hole on the side versus at the bottom = it goes deeper on the side) (and i haven’t been able to find models without the “gap” in the middle).
Barry kindly sent me some real pictures of the new LT1 colors. I think their anodizing team did a pretty good job, didn't they? Maybe we get to see these new colors packed with new features like full USB-C compatibility (PD charging) as well as reverse-charging, i.e. to use LT1 as a powerbank to recharge external devices.
Looking good! - My apologies for my limited correspondence over the last number of months, been crazy busy with the big move, settling in a new house, all that. I hope to chat more with Barry soon on the colors versions, accessories, and the Mini LT1 once i get back on my feet.
On Sofirn’s own site they are selling the 2 colors above as well as the orange, but they did not provide a photo of what the orange one looks like.
https://sofirnlight.com/ - says it supports C to C charging, but when you click into the item link is still says A to C charging???
I didn’t know these could be operated connected to a wall charger without batteries. Will need to try with my updated version. I guess if they support C to C charging this would be version 3?
