I'd like it, but... That button sure looks like a driver mount style - agree, Sofirn likes this style but they did do it the right way with the SC31B and SC31 Pro.
Ohh - with my SC31 Pro, I swapped the 6500K SST-40 for a 5000K SST-40. I don't see any loss in output. The output actually went up: 2100 (calibrated) at start now, running at about 9 amps (was 1980 at ~8 amps). I don't even bother with 30 sec measurements on lights like this .
With these LED's, the output is governed by the binning, and I didn't see the available 5000K's binned any lower, or much lower? Least I can recall. Even with the old XPL's, the bins of high NW's (5000K) matched the CW bins (XPL V6's, like used in the Q8). You drop bins big time for high CRI, or warm tints - that they haven't improved on yet.
I have one of the first SP35 and I agree with your assessment that the beam is quite not nice to look at. You wrote that Sofirn already updated the reflector, do you know if we can somehow get our hands on those new ones? I am quite happy with my buggy SP35 without thermal regulation though, would love to have a smoother beam.
I was told by Barry that the old reflector was only used on the first 100pcs. I don’t think enough people have received their SP35’s to know if it has been fixed.
I suggested using an OP reflector but Barry said to wait and see if the new reflector would be okay.
I’ll try and remember to ask Sofirn if they’ll sell the new reflectors separate
I ordered my SP35 back in Nov/Dec I believe when they didn’t had them in stock yet to send out. Arrived shortly after Christmas here, so I am pretty sure I have one of the first ones. No thermal regulation, gets pretty hot
I ordered the SP35 kit from Amazon on 06JAN21 and it arrived on 14JAN21. Kit was complete, with 21700 4000mAh battery, clip, lanyard, and O-rings (o-rings are in the small ziplock bag with the lanyard, look closely). I’m impressed with the output of this Sofirn, it lit up my 2-acre pasture (0.8 hectare for the rest of the world) very well. Eco mode is sufficient for me to walk inside my house with all other lights off. UI works as per owners manual, I like the double-click to go from Off to Turbo mode.
I received my SP35 about a week ago and have been playing around with it. Overall, I really like it! My review is up here
Pretty much everything I’m seeing is inline with what Funtastic has mentioned so far. The only exception is either I have an updated reflector or I’m less sensitive to the beam, one of the two.
Got mine today, but I am very disappointed!
With a full Molicel P42A mine barely reaches 5.4 A at turnon (tested with several cells and even VTC6, despite them not fitting…).
And it has only 21 kcd which is way below the 27.5 kcd that were promised…
That seems way off - is my flashlight defective or did you guys get similar results?
Hmm, I measured 24,250 cd which is just a little below spec. With regards to the amp draw, remember this is a buck driver, not a FET. Instead of burning of excess voltage, it trades volts:amps. You may be seeing 5.4A at the tail, but it’s likely still delivering 6 amps to the LED because of the buck.
Probably very little, the reflectors can’t be very different in dimensions, the emitter is the exact same and is driven to basically the same level (maybe a bit less even).
It looks like they’ll also be stocking it at Amazon eventually (non-aff link). I bought mine through Amazon; it shipped from China and arrived relatively quickly. Good pricing on the one directly from Sofirn’s website. When I buy stuff there, it usually arrives within a couple weeks - pretty fast for China shipping.
