Recently I got my BLF LT1 and it has a spare USB cover together with the spare o-rings. You should ask Sofirn if they can send you one. They should have it available as a spare part.
Do you know which screws (with which dimensions) to buy and that would fit the BLT L1 screw holes ?
I ordered these ones (flavor “LS047” / screw 4.5mm + additional height 3mm), and sadly they don’t fit well (and not in the same way between hole on the side versus at the bottom = it goes deeper on the side) (and i haven’t been able to find models without the “gap” in the middle).
https://fr.aliexpress.com/item/4000767201624.html?spm=a2g0s.9042311.0.0.27426c37KX5AC1
Never tried but I’m 99.99% sure these would fit.
You simply need standard photography tripod screws. Nominal size is 1/4-20
PS: ces vis sont disponibles au sur Amazon Canada, j’imagine qu’elles le sont également sur Amazon France ?
Sure, I’d like to give it a try! How bad is the bumpiness?
Barry kindly sent me some real pictures of the new LT1 colors. I think their anodizing team did a pretty good job, didn't they? Maybe we get to see these new colors packed with new features like full USB-C compatibility (PD charging) as well as reverse-charging, i.e. to use LT1 as a powerbank to recharge external devices.
only 2 new colours?
I really like that dark green. The other one just looks black on my monitor; how would you describe the color, Lux?
Looking good! - My apologies for my limited correspondence over the last number of months, been crazy busy with the big move, settling in a new house, all that. I hope to chat more with Barry soon on the colors versions, accessories, and the Mini LT1 once i get back on my feet.
So where do I sign up for the green one and how soon can I get it?
I assume they’re just using what they’re familiar with. These look like the EC01/3 colours
On Sofirn’s own site they are selling the 2 colors above as well as the orange, but they did not provide a photo of what the orange one looks like.
https://sofirnlight.com/ - says it supports C to C charging, but when you click into the item link is still says A to C charging???
I didn’t know these could be operated connected to a wall charger without batteries. Will need to try with my updated version. I guess if they support C to C charging this would be version 3?
I’m assuming the Attiny85 doesn’t have enough pins/legs/whatever they’re called to support a third channel? I’ve been using my LT1 as a bedtime lamp in sunset mode and would prefer the lowest pwm mode to go a bit dimmer. I might just remove one of the 0 ohm resistors on my driver board but I was wondering if there’s the possibility of DIY-ing a single 7135 third channel.
Would something like disconnecting the switch and connecting a 7135 to that channel work or is that leg not a pwm possible leg? I wouldn’t mind having my switch just constantly dim and using the provided potentialometer to adjust the switch brightness.
thanks
@SR-G If you like ali, here’s the ones that match: https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20210124121324&origin=y&SearchText=Dslr+1%2F4+strap+screw+d+ring
Another interesting option that can be used is the magnet with the Dslr 1/4 screw
Has anyone heard anything about the production of more orange LT-1s? Seems they’ve been out of stock a while and I haven’t gotten anything in reply from Sofirn except that they are out of stock.
Has anyone actually received an orange LT-1?
I ordered one while the sight said they were available, only to be told that they weren’t available. I waited 12 days and nothing shipped.
I finally asked sofirn to either refund my money or switch my order to a green lantern, which they sent yesterday. When I contacted Barry
he told me they were waiting on anodizing. Sounds like they were never really in stock.
I am waiting on an orange also. Sent them a message they said 20-days two days ago so 18-days now who’s counting
later
Thanks for the replies. I am wondering if perhaps they were mistakenly listed for sale prematurely as it is my understanding is that no one from the posts about orange LT-1s has seemed to actually have made it through the process to receiving one.
That would be great, here’s to hoping 2 days is the magic number
Here’s the thread about the colored versions:
It would help others if the discussion about colored versions of the LT1 would be all in the dedicated thread :+1:
Thanks, angerdan, I forgot about the color thread. I’ll post there as well. I had noticed there were posts over here where people had attempted to order some and had failed. This thread is a beast.
