Not really sure. 1000 lumens from a XPL-HI, assuming V2 or V3 bin is maybe 3-4 amps or so (??). Could be dependent on the driver - might not get the same 3-4 amps on a LED with a much lower Vf, like the HX. So the amps could be a problem, plus the condition of the LED/reflow/variations, etc. Not to mention focus/optics issues.
A high amp OSRAM is probably not the best choice for this light with no driver changes.
I was outside for a bit now that it’s dark, and I’m a bit confused. I compared the NEW P30 against my modded Manker U22 V2 which I’ve measured at something above 200k lux (my lux meter doesn’t go any higher). I have to admit that the throw distance of both lights seems about equal to me, the NEW P30’s beam is significantly wider though. Both provide about equally bright illumination at about 500 meters, past which I can’t really see anything anymore anyway. I don’t have any points of reference farther than 500 meters so I’m not really sure how the comparison plays out for longer distances, the Manker sure had more reach but not in a terribly useful way.
So now I’m considering whether I just suck at measuring throw. I’ll redo it at different distances to the lux meter sometime.
Anyway, numbers aside, I’m quite happy with how the NEW P30 turned out. I hated the original beam and if nothing else, that has drastically changed for the better. So that’s ten bucks well spent.
If Barkuti will see this he will know I am not the only one on the FET side of the world… I also have problems that certain drivers does not deliver declared amperage output… I know regulated light should be better but for my needs FET would be sufficient plus it generates zero heat on the driver board.
Yes I know it looses a lot of performance as battery drains… Especially those 8A emitters… But performance drop when used with certain types of emitters (4-5A emitters) is certainly not that noticeable with naked eye giving up decent performance “on turbo” up to 15 minutes of runtime, after that it is noticeable…
So Guys who use FET knows that they got to use turbo mode sparingly and that is it…
They use the same die but different package. CSLPM1.TG has worse thermals, that’s why Convoy choose to run it with 2 amps less.
Overall CULPM1.TG will be brighter but hotter.
Assuming equivalent bins, at low currents they would be the same. Once heat starts playing role, CULPM1.TG will be better but up to 6A the difference would be very low.
Not so slightly. 2mm² Osrams should be almost half way between CSLNM1 and XP-L HI and actually a little closer to XP-L HI. And in Z1 they have a rectangular beam.
I just saw this light today. Searched BLF and there are only two mentions of it sitewide. I agree PM1 maybe makes more sense, but it still maybe the most desirable Lumintop in recent times… except it looks like a FET driver. Wonder how that’s gonna work out
EDIT: Also, hold for off UI. Well they sure do know how to eff something up don’t they.
The X1L has 8 AMCs and no FET. For whatever reason they were unable to just modify the FW21 driver accordingly and still run Anduril, and the X1L uses a different MCU that isn’t as easily reflashable.
I put a FW21 Pro driver in mine and flashed it with Anduril, using the 219C config. Much better that way, and the LED seems to handle it very well. You can get the driver from Lumintop’s AliExpress store for 8 USD.
