Could not figure out yet, if I actually need these, but they are lovely to look at (TIR optic is also a big plus).
The TIR optic and multiple battery tubes makes this one a buy for me.
Are you sure that driving the emitter that hard (6A) makes sense?
Because as you can see above, even with much better cooling the brightness is almost flat between 5,5A and 7A. Going down to 5,5 or 5,3A would net pretty much the same brightness and throw while using 15% less energy (longer battery life, less heat etc).
LED4Power tested the 5Q flux bin. FF was able to procure the higher 6Q flux bin. Not sure if the 6Q would max out at a higher amp since it hasn’t been tested.
Yes, they’d max out at the same current and a slightly different brightness.
Are these for sale now?
It doesn’t quite look like it yet - All I get is a “Send Inquiry” button:
I’m super excited for mine to arrive though (courtesy of the Old Lumens Challenge prize)
Are the two holes on the tail cap for a pocket clip? Does the light include it? I hope so.
Does the 21700 tube come with the light? I have the fireflies eo1 osram and it’s a tiny bit smaller head… 2 mm. And the eo1 does not come close to the 125kcd that this new t1r supposedly does. Maybe only 35kcd. Good job if these numbers are accurate.
I think the tube will be an add-on. I asked if it was included with my prize (and was hopeful I’d be able to tag it on in the same package if not) but didn’t get a response
I wouldn’t expect the numbers to be much different from what other manufacturers have come up with using the Osram and TIR combo. Though from the reports of the Acebeam, I’m not sure what the actual numbers there are.
I don’t think there’s a pocket clip those look to be for a lanyard.- looks like it is for a clip, see below
At least based on this cropped image from the OP, those holes appear to be threaded. I’m guessing you’d screw a clip on there?
On their website it says, With stainless steel clip but it doesn’t show a picture of one.
I like the removable tail magnet and 21700 extension
Im ready to order Army green!
It said available Jan 25th and it is the 26th and I don not see where it is available yet.
Patience please FireFlies is not a large company, so I usually tend to forgive for some delay (I handle these dates as just promises/plans, not actual deadlines), I just look at the result of their work.
They didn’t say what year. Just pretend they said FEB 25th for now. I’m waiting for this one too.
After Chinese New Year
Interested, looks nice
How well does the red head, body tailcap color match? Interested in a red with both the short and long body, any discounts for BLF?
What is the lenght of the light with the 21700 battery
Skylumen just released a mt01 that kinda looks like the fireflies t1r. anyone else think so? Im still waiting on the fireflies t1r. I can’t wait
Mateminco MT01 is the Astrolux EA01.
