First thanks to this forum for the great info and suggestions, especially the Sofirn SP40. I’ve always wanted the equivalent Zebralight, but couldn’t justify the cost for occasional use.
I had a question about the C01 / C01s - are there any tricks or hacks to stopping the end coming off in your pocket?
Previously the only twisty torches I’ve had were maglites.
As much as I love my C01 getting that balance between will not accidently turn on and too loose is tricky.
The grease has become a bit thicker over time so that my C01 does not often unscrew itself in my pocket, but last week it happened again after a yearvin my pocket without problem. You could try thicker grease perhaps?
Thanks. I’ll have a look at what I’ve got in the shed.
Pretty sure it’ll just be normal, copper, or silicone.
Thinking about it red rubber grease is quite stickly and I’ve got a little pot of that. No idea what it’s like on metal threads though as I’ve never tried it (for the obvious reason).
I also like the newer 3,400k Sophia better than the 3,200k Yuji.
The Yuji Tint seems a bit “muddy” by comparison and my perception is that cri is lower.
Yes. And some hosts. OTOH, they’re still at $3.99 (white) and $4.49 (red). I think they are gifts to the community and wouldn’t expect any kind of service or spare parts.
