I would like to ask a question to the owners of Astrolux EA01 (or Mateminco MT01), who have a blue flashlight. I see that the TIR optics are transparent and have the ability to see anodizing from the inside of the head. Does this affect the light? Perhaps it was from these considerations that I ordered myself a gray one … It seems to me that some spectrum drift into a colder one is possible. Interesting in the SST-40 5000K version…
I just got in a blue EA01 XHP50.2 5700K, already had a grey MT01 SST-40 5000K. I don't think the color of the anodizing effects the beam/tint, but someone who better understands the optics would know better. The blue shell sure looks blue. I got a FT03 in blue and think they match up pretty well. I do know they use something like plumbers putty to cover up the switch hole and it's wires - not sure what that's about, but it's in both my EA01 and MT01.
SS head had some sharp edges, actually burrs - used a rounded file to file them down, all good now. Probably would have torn up a pocket pretty good.
noticeable fibers and specks in the optics. Not sure where, either on the optic or MCPCB or both
some small amounts of what appears to be a clear glue on the outside of the tailcap. Didn't remove them yet, but not a significant issue.
Noe of those issues, or anything else noticeable was with the MT01, though it's probably just luck of the draw, doubt it's because one is Mateminco and the other Astrolux.
Thanks Freeme. My EA01 50.2 arrived yesterday and I couldn’t be more pleased with it. Took about 3 weeks. Does anyone see a violet colored center dot when white wall hunting from about 10 feet away?
Huh. I only see it inside so no biggie. Was just wondering. I have been using mine at top of ramp mostly (default). 5500 Shockli goes down fast at that setting. Care to guess what lumen level 120/150 is? I don’t think you can just multiply .8 x 3500 to get a ball park and I don’t have any way to measure lumens.
Well, these are indexes in to the ramping table. The ramping table is logarithmic, not linear. So, 120 of 150 is programmed at about 1/2 the max amps (I think, at least from memory). So I believe in theory, you should be at about 50% of max lumens. PWM'ing a FET at 50 % (I think) results in about 50% lumens.
We use TK's Python script to generate the ramping table data that does the logarithmic conversion of basically amps to perceived human eye brightness. The poor examples we've seen of ramping, where it seems to take forever and changes fast at low settings and super slow at high settings are ones that do straight linear ramping.
I have my doubts about this. Even neglecting the technical absurdity of this, the 21700 adapter simply won’t fit into a narrower tube. Judging by the video, where it fits tightly into the blue one.
