I am listing my Fw21 Pro (3 x Xhp50) led light. It is used, in very good shape. It’s my vehicle light, so it gets use maybe once a Month.
The xhp50’s have been dedomed. Gives a nice bit extra throw, and a bit less Lumen output as you all know.
I love the beam pattern, the form factor (21700) and feel in hand. It actually fits in the pocket well. The way I have anduril set the max temp and ramp are moderate, and it’s quite a useful light. I just never use it. Here are the details, let’s see if anyone wants in:
FW21 Pro (3 x xhp50)
Dedomed
Original box, orings, etc included
A couple nicks, no scratches
Can included Lee’s Minus (1/4 green) filter if interested too.
$50 $40
Conus only
Shipping with tracking included
PayPal G&S only
I am not including a 21700 in this price as the cost of 40t’s (what I have) have gone up so Replacment is a little more painful, but if you need a 21700 and are interested we can work something out.
I’m possibly interested; but I have to ask, about how much would a decent/good-quality 21700 battery for this flashlight cost? And any recommendations on where to try to buy one?
Also, any feedback on what the runtimes are like? Can it maintain Turbo for more than 1-2 minutes, before it steps down? Is the stepdown from Turbo drastic? And is the High output impressively bright?
And any recommendations on where to try to buy one?*
30T or 40T are the best for this arguably. I can sell you one with it, mine are genuine and I buy only from (18650batterystore.com). Mine are in new condition, id charge $5. If you want a new one, I would suggest buying from 18650 battery store.com, or liionwholesale.com. You’ll pay $6-$8 then about $5 for shipping. Better to buy more than one to justify shipping.
*Also, any feedback on what the runtimes are like?
* I use the Samsung 40T to get more time out of the light at with the higher voltage. Runtimes are completely dependent on how you use it. With such a wide range of lumens, it is hard to say. You can run it at below 1,000 lumens for hours with a 40T, or get 10’s of minutes if your running it over 4,000 lumens. Like most any other high powered light.
*Can it maintain Turbo for more than 1-2 minutes, before it steps down?
_I have not tried it, but it is unlikely. I want to be honest, this light is self admittedly a hot rod not meant for blast mode for long. If you set thermals hot, you might approach a minute but it’ll get hot.
_
*Is the stepdown from Turbo drastic? And is the High output impressively bright?
_Step down from turbo is in stages and you can always bump it back up depending if you want to hold a hot flashlight. I cannot stress it enough, this light is a very compact lumen powerhouse. It can absolutely be used as a normal light (1-3,000 lumens) and is actually very good at it. But you are using the turbo mode for brief 20-45 second times.
It is definitely impressively bright for its size. It’s brighter then my mf01 mini and more compact. It depends what you’re comparing it to._
also, there is an included battery adapter, so you can run 18650’s. Sony vtc6, Sony vtc5 series, Samsung 30q, Samsung 25r, molicel p26a would all be good quality batteries for this as well.
