Code BG1128 raises the price to $213.45 .
Isn’t it suppose to lower the price ?
Mine arrived today, its incredible. I have several other throwers, but this is my first LEP and the singular point of light is very cool. Something to be said for not blinding yourself by the spill and being able to keep the overall light level down and still see what you are looking at.
The ring works well, it has audible/tactile clicks when changing modes, and it works magnetically as these usually do (confirmed by placing a refrigerator magnet next to the ring which switched the mode briefly). Low is still pretty bright when close, but its design is for distance, so that’s reasonable.
I notice the beam seems to be narrowest about 6 feet in front of the lens, then it broadens back out again. This leads to a spot with a diameter of about 2 feet at a distance of about 120 ft away. This focusing might be adjustable by tightening/loosening the ring that holds the phosphor in the body to bring it closer/further to the lens. I’ve no plans to do so, this is a good beam angle for my needs, but I’d guess it could technically throw farther if carefully adjusted to be as much of a cylinder as possible rather than narrowing and widening again.
My Astrolux WP2 had just arrived upon initial impressions its a very nicely built light solid construction love the UI probably the best UI for this specific light. As for measurements its still daylight out but initial measurements from my meter is VERY promising but again my measurements are amateur at best.
Just forwarded you our GB info.
Thanks for sharing your firsthand experience of WP2.
That's really a great piece of news! Guess our hard work has paid off.
Coupon BG1128 not working - getting message “invalid coupon code”
freeme - Please send coupon code to my PM - thanks!
As long as the WP2 does not underperform like the RRT M1X…Please send a coupon code! Ready to buy…Thank you!
Shared. [quote=tamadedan] As long as the WP2 does not underperform like the RRT M1X...Please send a coupon code! Ready to buy...Thank you! [/quote]
The WP2 had a slight edge over the RRT M1X. But is beaten by a large margin by the W30, W4, M1X Wp-Rx, especially after the drop-down @ 3minutes. After 3 minutes it's not really impressive anymore.
Good to know @ChibiM. I wonder how much of that is because of the wider beam pattern. What I am more interested in than outright performance is the rotary UI: If it is as satisfying as the magnetic ring on the Polarion PH50, then I will be satisfied to some degree. The ability to move from low to strobe (with the L61 diffuser) may make this a nice residential walking light (strobe while crossing the street). Order placed.
If not completely satisfied after some time, perhaps I may send it to Vinh to turn it into a WP2vn
That's true, I did reviews on almost all popular LEP flashlights currently available (13 in total).
Links are in the LEP discussion thread here: https://budgetlightforum.com/t/-/63612 so we don't get too far off topic here.
48hrs FLASH SALE
FREE MEOTE FM1 4* LH35 1D/SST20/XPL-HI 4980LM
with purchase of ASTROLUX® WP2+WP1 Combo / ASTROLUX® WP2 / ASTROLUX® WP1
freeme Is the GB code for the WP2 still available?
Price is listed on original post now.
WP3 is coming.
Are you referring to the pre-flash on activation?
Yes
