Test/review of Klarus LiR16340 700mAh (Red)
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 12 hours ago
DSC_9314
Official specifications:
  • Battery Capacity (Mfg Rated): 700 mAh
  • Battery Chemistry: Li-Ion
  • Battery Feature: Protected Rechargeable
  • Battery Form Factor: 16340
  • Battery Maximum Voltage: 4.2 V
  • Battery Minimum Voltage: 2.75 V
  • Battery Rated Voltage: 3.7 V
Klarus%20LiR16340%20700mAh%20(Red)-info
Klarus is mostly known for flaslight, the also have a few chargers () and rechargeable batteries for the lights. This is the smallest one.
DSC_9312 DSC_9313
DSC_9315 DSC_9316
DSC_9317
DSC_9318
DSC_9319
Klarus%20LiR16340%20700mAh%20(Red)-Capacity
The discharge curves looks good, they track nicely and the battery can deliver about 2A with protection tripping a bit above 5A
Klarus%20LiR16340%20700mAh%20(Red)-Temp-2.0
Klarus%20LiR16340%20700mAh%20(Red)-Temp-3.0
Klarus%20LiR16340%20700mAh%20(Red)-CapacityTimeHours
Klarus%20LiR16340%20700mAh%20(Red)-Energy
Klarus%20LiR16340%20700mAh%20(Red)-PowerLoadTime
Klarus%20LiR16340%20700mAh%20(Red)-TripCurrent
Klarus%20LiR16340%20700mAh%20(Red)-Charge
Conclusion
This 16340 (RCR123) looks good, it can deliver some current and has good capacity. The protection makes it applicable for many devices, as long as it will fit (it is slightly longer than a CR123 cell).
Notes and links
Comparison to other LiIon batteries
hiuintahs
I got me several of these Klarus 16340 batteries recently and they performed as well as the Fenix ARB-L16-700 on a run time test that I did………….which up until now, the Fenix was the exclusive 16340 battery that I would buy. Comparing the chart of battery info that HJK has done with that of the Fenix 16340 they are very similar. I think the Fenix and also the Klarus 16340 batteries as the two best 16340 batteries that I’ve seen. With the Klarus being less expensive, that kind of makes it my go to 16340 battery now.
Grateful for all the work and contribution HKJ has done over the years. It’s been very helpful for me. If it wasn’t for the test and review of the Klarus, I probably would not have purchased as many as I did the past week with Black Friday and Cyberweek. And probably would have only purchased one just to try out before risking any $ on more.
Right now very pleased with the Klarus 16340.
utor
Hello, I have a (maybe stupid) question. I have the version of this battery with a usb-port. Would it be possible to charge a device via the micro-usb port if the battery is fully loaded? Could be usful as a mini powerbank then... I would like to try, but I am hesitant to mess up my battery or the device by just connecting w/o having a clue... Thanks! utor
hiuintahs
Hello utor. If I understand the question correctly you want to use the battery which has a charging port also as an output. That won’t work because that USB port is an input only for charging that battery only and doesn’t have the capability to also output power out it. Hope that helps.
utor
Thanks a lot for that fast and helpful answer! Then I have to think about another solution… Smile
