✌ ASTROLUX K2 300lm Keychain USB-C Flashlight
Side LEDs should be identical for all shell colors.
Ordered one purple 4000k. Thanks Freeme!
Interested
Possibly.
Huh? It says right in the Banggood listing:
“2. Because of shells with different color, light colors of sidelight may be a little different”
That is correct. I have not seen the actual product yet, but I am quite sure that will be some color shift for colored models. For example, red LED output projected through starry blue shell will give slight purplish tint to it (to be confirmed).
Can you explain the operation UI . I don’t quite understand.
“Operation (machine translated)
In the operation logic shutdown mode,
Click to return to the stepless dimming memory position. Long press to enter the stepless dimming. Default minimum brightness. Long press until extremely bright.”
I long press to turn in on/off? Then let go and press again to adjust brightness? Or is it single click to turn on/off and it starts from last brightness level.
This ^ +
Long click from OFF to start ramping from the lowest setting.
Then, from ON (and even from OFF), there are other options to access Turbo, Strobe and the other Leds.
Oh if that’s the case then I don’t think I’m interested, for a keychain light that sounds like a lot of accidental on/offs when it’s in the pocket/purse with single click on/offs.
Interested
isn’t that what lockout mode is for :question:
if i don’t lockout my fw3a it would turn on 20 times a day
Final.
Order placed for 2. Thank you!
I’m interested if not too late. I like this form factor but sadly another popular brand has let me down. Willing to give this one a shot.
Ordered 1, cheers!
Ordered 2!
Hi all, I am a newbie, how to join the group to buys this product?
Interested
Ordered 1
Interested.
