I took measurements and posted here
Yes, amazing output, floods night into day. One thing I’ve noticed though which differs from my
other Anduril lights is that, this one must be fully ramped up to high before it will go into Turbo.
If it is not on the highest ramp, double clicking will only take it to max ramp, then if I double
click it from there, it just returns to the previous lower ramp setting. Not a problem
now that I know this but I wonder why they would have set it up this way? On all of my other
Andruil lights like those mentioned in my original post along with the MF01S, I can jump to turbo
from any ramp level.
It’s a change for anduril 2.
That is not a Fireflies decision. It is how Anduril 2 UI was decided by TK and the BLF community. Though personally I dont like having to ramp to top of ramp inorder to double click to turbo.
I like the ability to access top regulated setting via a shortcut, but it would have been nice to reach full turbo as well from any setting. Example 2x click to top of ramp, or 3x click to Turbo
Triple click to turbo would have been nice. Or at least double click to top of ramp and double click again to turbo.
I think it is possible to change 2 click to turbo in Anduril firmware, but you are correct that Anduril2 UI change a little from Anduril1.
I agree, I would prefer the old system letting you access turbo from the lower settings but, at least I know
now so it’s not a huge problem.
OK thank you… a little annoying but no regrets on the purchase.
You can access momentary turbo from any brightness setting by doing a click-click-hold from on.
FireFlies, have you sent my order 3942? I am waiting it since December. You said you’d ship it after the holidays, but I dont see any news.
Or should I make “Negative experience with FireFlies” thread?)
FF don’t check BLF threads. Try to email and PM them.
I have been repeatedly trying to reach Jack on Wechat ever since CNY have passed. No luck so far. :-( Before CNY he always replied very quickly.
Did you check your order status (view details)? often, they don’t let you know it shipped
Mine shipped like week ago silently but my order number is 500 higher than yours
They don’t check email too.
Yes I checked order status.
I will try PP desput then.
Hi,
I ordered 30.01 and got my Trackingnumber 20.02
They were on Holiday from 05.02 - 20 .02………
In my opinion they have many Problems with Communication.
This is no FET light, or FET present for FET turbo? And if it with FET - why D4V2 uses no FET builds for E21A?
Fet is active only on turbo. This thing has 21 E21As. Assuming you get about 20 amps from the 21700, you’re only putting 1A through each emitter.
Yup, that’s pretty accurate. With a Vapcell T50, I saw 22.4 amps (just over 1A per emitter) before the voltage started to sag.
