Please PM me for the code, I can’t PM you directly.
The PM function back to normal right now.
Thanks for your suggestion.
Interested in a code for the S11C please. Thank you!
Code for s11c please, I’d love 3 if possible.
Could I please have a code for the S11C, Thanks!
S11C is a great deal for $8. Works great. Nice neutral beam tint. Direct to moonlight or High from off. Hidden strobe. Smooth zooming function. USB-C charging. Strong magnetic flat base. Cell and cable included. Might be best $8 I ever spent on a light.
All functions tested and work fine.
Keep it away from water - check! $8.
Only complaint no spare o-rings and needed to grease threads. Not a big issue.
Thanks for the deal Sofirn.
Yeh, think I got a half-dozen S11Cs between me and the gf. Great for gifting to The Muggle, too.
Cheap but definitely not a “toy”. Similar to the LEDLenser type zoom? It’s not the usual aspheric, but more like a sliding TIR lens.
And the SD01 is a nice light, too. No end-cap on the battery tube, but one solid milled piece, so no leakage or O-rings to mess with there, either. Nice!
Codes for both, please
Thanks
I would like to get a discount code for the SD01.
Thank you.
I’d like the code for the S11C please.
Thank you,
Could I please have the code for the SD01 light? Thank you!
Hi I would like the code for the SC11.
Thanks,
Scott
Hi, the sd01 flashlight code has been sent to your message, please check it.
Hi, the code will be sent to you when S11C is in stock on Amazon. Thanks for your patience.
Thanks,
Scott
Can I have the code for both lights please? (Not sure how to send a PM)
Code for both please
Lol, the code has been sent to your meaage, please check it. It doesn’t matter that you don’t know how to send a PM, I’ll PM you.
