I think so
I’ll go try.
Nope, doesn’t work. Not with the dot, not without the dot. Ie BLFuser. $212.46 with shipping and you know what? It’s fine. They’re good folks, I’ll pay that anyway.
Works fine from here: blfuser
Thanks Jimo, and Illumn. Works for me.
Ilumin is hands down the best. As a matter of fact I’m waiting for my BLFGT94 now coming by the end of the day.I ordered it from Illumn last week.
You can actually go to their store in San Jose, CA.and try out some flashlights
I would love to go to the Illumn store and meet The owner Craig. He’s one Hell of a great guy. But South East Michigan is a long way from there.
Thanks for the code Jimo!
Wasn’t me it was Craig but if you purchase from him tell him I sent ya
“blfuser” is no longer functioning. Anyone know what’s the replacement, or is Illumn done with BLF discount codes?
It’s capital BLF, and lower case user. BLFuser! Worked for me about 5hrs ago
Tried “blfuser”, “BLFuser” and then both with exclamation point… none worked. Is there an order minimum?
I’m not sure bud. My purchase was $12.45. So if there is a minimum, it’s set pretty low.
It may only work a certain number of times per day? Just an assumption. BLFuser is the exact code that worked for me today.
Edit… I just went on illumn and put stuff in cart, tried code and it worked
Have you used it more than once? I might have used it last year… and then that would explain it. I’m quite proficient with the keyboard. Haven’t made any typos…
Yep I purchased some suff with the code back June 2021. Maybe try a different device to place the order.
Even went to a completely different browser, no illumn cookies, logged in, my cart reflected the item I’d added before, went to checkout, tried both “BLFuser” and “blfuser”—they gave the same error as above. Simply won’t work for me. I don’t get it… Maybe there’s bias with delivery to my state (not in California).
Your right! The code doesn’t work on rovyvon angle light. I just tried, probably because it’s already discounted steeply. Bummer. But if you need batteries and such, the code will work.
