Main features:
*Super mini size of Φ15.8mm*57.6mm(L), weight 18.5g, perfect for everyday carry.
*Using CREE XP-G3 LED, 20000 hours of lifespan, max output 500lm.
*Five levels for white light: Moonlight(2lm), Low(50lm), Mid(150lm), High(300lm), Turbo(500lm).
*T1 has five light colors, white, red, green, blue and UV (395-400nm), with various lighting modes
*T1-UV has UV light (365-370nm) for detecting countfeit note, cat/dog urine, and fluoresce agent
*USB Type-C input with built-in rechargeable Lipo battery, easy to charge.
*Humanized memory function helps switch back to the last mode easily.
*Charging indicator - red in charging & green in fully charged.
*Using AL6063 materials, firm and durable.
The UV one it says - ‘Uses one CREE XP-G3 LED and one 365-370nm UV LED’
Yet in the photo it appears to have 3x uv led? which is it please? 1or 3? if not 3 what are the other 2?
If the UV led’s are really 365-370nm (NOT 395-400nm) that would be very nice.
Even with a 5mm 375 nm UV led it is possible to identify the safety markers on EURO banknotes.
A proper 365nm led + ZWB2 filter would be ideal (of course), but 365-370nm led’s ain’t half bad.
And the body color of that thing is quite “stimulating”.
