Ff light
218 posts / 0 new
Jimo
Last seen: 8 months 3 weeks ago
Ff light
Hey does anyone have any information about the fireflies new light that’s supposed to be ready for pre-order this week. The light is the E07x pro.I have been looking for information about it, and the guy from ff hasn’t gotten back to me. I think his name is Jack. He mentioned it last week in a email.
Jimo
Sunnysunsun
Sunnysunsun's picture
Last seen: 4 months 1 day ago
It’s the E07 with the new buck driver and probably the same threads issue as all their new lights using that tube
ArtieT59
ArtieT59's picture
Last seen: 1 hour 9 min ago
I’m very curious about the EO7X pro too. I ordered the E 12r today and want to order a brass Eo7 but remembered this e07x is supposed to be coming. I wonder if they’re going to use the same emitter options as the e12r or if they will have XPL hi’s like the original E07? I hope he offers xpl-hi.
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
Jimo
I have know idea. If you get any info please share it with me and I’ll do the same. Thanks Jim
Jimo
Shakira08
E07X PRO .. LED – 7x Luminous SST20, CREE XPL HI, or Nichia 219B SW45K R9080
Body color: Matt Black / Navy Blue / Deep Red / Army Green
Max Output: 7000 Lumens
Max Beam Distance: 680 meter ( XPL HI version)
with 6 x RGB auxiliary LEDs
Durable electronic side switch
High efficiency 6A constant current buck driver (>90% efficiency) with FET Turbo
True 2A USB-C in-built smart battery charging capability
Ultra-clear AR coated optical glass lens
10-degree beam angle TIR optic
1x 21700 lithium battery, or18650 battery with included adapter (battery not i ncluded)
Operating range 2.7V to 4.3V
Dimensions
○ Head Diameter – 38.5mm
○ Body Diameter – 26.5mm
○ Length – 85mm with 22430 Body ; 123.5mm with 21700 body
○ Weight – Approx. 120g / 5.29 oz without battery
6063-T6 aluminium construction with stainless steel bezel ring
Durable type-III hard anodized coating
User Interface
○ Latest Anduril2 open-source firmware with Simple and Advanced UI
■ Simple UI: 6A maximum regulated current
■ Advanced UI: 6A maximum regulated current with FET Turbo
○ Fully configurable modes of operation: smooth ramp to stepped ramp
○ Fully configurable auxiliary LED effects and modes
○ Automatic, manual, or hybrid memory modes
○ Continuously monitored battery current, voltage, and temperature with 2.8V battery cut-off
○ Ability to customize highest and lowest output levels
○ Ability to customize thermal regulation (50C by default)
○ Large variety of beacon, SOS, tactical strobes, and special effects including:
■ Candle flicker, thunderstorm, bicycle light, sunset timer and more!
○ Readout of battery voltage, internal temperature
○ Electronic factory reset capability
○ Lock-out mode capability
○ Manual: http://toykeeper.net/torches/fsm/anduril2/anduril-manual.txt
Hope this helps, if not allowed please delete…
P mitchell
Sillen
Sillen's picture
Last seen: 2 hours 3 min ago
No thread issues with my E12R
Jimo
Thanks for information. Did you see a price anywhere. Jim
Jimo
Sunnysunsun
The threads bring a feeling of unease every time I use them. Granted I haven’t accidentally stripped a light’s threads before but every time I changed the battery of the Nov-Mu, it felt like 1 wrong turn would result in stripped threads so I’ve been really careful and try to stick with usb charging.
Dalamar
My nov-mu looked pretty clean from the bits you can see, but yeah, like others mine will turn on before you even get the head on…threads and/or anodizing on them must be awful
Don’t unscrew the unanodized end cap… no reason to
Favorite lights:
Fireflies NOV-MU 21 4500k E21A
Fireflies NOV-MU 21 200k E21A
Fireflies ROT66 219B SW45 D220
Fireflies E07 Copper 219B SW45k? (odd/higher lumen bin with lower r9 and higher cct?)
Fireflies E07x Pro sst20 FA4 4000k
CRI test dump https://drive.google.com/drive/folders/1kcl_uOhgfpR4RSsa8F4b-UUVP9mkL6Cr...
Jimo
I am just learning about CRI
Jimo
ArtieT59
ArtieT59's picture
Wow.. this is awesome! Definitely buying this, so glad I didn’t buy the v1 this week. Thank you so much for sharing shakira08! You wouldn’t know where I can preorder do you? Thank you!
ArtieT59
ArtieT59's picture
If the head threads are this bad I’ll just strip them on the battery tube, I e-lock anyway.
atobe
Last seen: 11 hours 32 min ago
https://www.firefly-outdoor.com/OSG/showproduct.php?id=226 specs are here. I’m guessing it’ll be $98 (since most of their new lights are that price) with short tube+battery option for another $25 (as said in the T1R thread)
ArtieT59
ArtieT59's picture
Thanks! That’s a premium cost for short tube and battery btw.. i saw that price somewhere else too…
Sunnysunsun
Jacky told me $25 because he wants to sell it as a set with the unique battery. $25 shipped to Canada because apparently shipping to Canada has gotten expensive. You might be able to get a cheaper price shipped to the states but idk
Jimo
My decision to purchase one will depend ,in part, on whether or not I get a response from them. I WILL NOT purchase any product from a manufacturer that doesn’t deem it important to respond to a customer’s emails. If you can’t get a response from the company before you purchase what do you think will happen after a purchase, when you have a issue. I have tried contacting company for 2 months now.I have received 1 response i think on the 12th. I posted a follow-up email that same day and still ,no response. If you go to website and go through the “Contact us”,the email doesn’t even go through. I am very interested in the E07x pro,but will go with another brand if I don’t receive a reply soon. Jim
Jimo
toddcshoe
toddcshoe's picture
Last seen: 5 hours 51 min ago
Wait. While a agree that customer service should be important. Do you really contact all manufacturers before purchasing a product? I bet you scare the bejesus out of Charmin. Big Smile
Don’t know how use you are to contacting support folks whos native language is Chinese. I always give and take this same advice. Always keep your correspondents with them dead simple. No long drawn out explanations or needlessly complex questions. Just short and too the point. No American slang or shorthand either. I have always gotten positive responses when I follow my own advice.
I can’t fix how long it takes for them to get back to you. That just seems to be a issue with one man shops trying to make it in China. Most of these guys don’t make their living on flashlights alone. But, if you make it easier for them, they may make it easier on you.
"Everywhere I go, there I am"
Jimo
Besides astrolux and ff. I have know problems communicating with any manufacturers. It isn’t about the messages, Its about the respect the manufacturers have for their customers. Also the U.S supplier of FF I have found to be dishonest. But I don’t believe at this time that to be a accurate portrayal of the FF brand.I have sent a inquiry through the new website, so.I will see what happens.
Jimo
Jimo
Oh and Nealsgadgets. Dosent responded regularly as well.
Jimo
ArtieT59
ArtieT59's picture
So i just ordered yesterday, from FF-light.com. Now of course i see this thread hours after placing my first order with them, and the link for firefly-outdoor.com was shared for the e07x pro. I ordered from a different website – ff-light.com. Can anyone confirm FF-light.com is also a legitimate sight to order from? I apologize if this is a dumb question, i just got a little nervous when i saw there was a second website posted in this thread. also, no confirmation email yet.. thanks
Pip
Last seen: 1 day 10 hours ago
Ff-light is legit, ordered from them several times. Never heard of the other site until today.
ArtieT59
ArtieT59's picture
Thank you, Pip! Gives me peace of mind. I also remember reading on blf somewhere that you don’t always necessarily get a order confirmation from FireFlies . So I’m not as worried now that I know the website I used was legit. Thanks again!
Jimo
I’m thinking that website has just been updated and looks different. Didn’t mean to imply that it isn’t ff legit sight sorry for that.
Jimo
ArtieT59
ArtieT59's picture
No problem at all jimo. I just wanted to confirm I didn’t make a mistake
Th558
Th558's picture
Last seen: 3 hours 1 min ago
680m with XPL HI…Must be a typo.
Jimo
Eo7x pro?
Jimo
Sunnysunsun
Why so much post deletion?
Edit: oops I was looking at the wrong thread Facepalm
ArtieT59
ArtieT59's picture
I noticed that too.. was hoping they sourced a really narrow & efficient optic? Does seem pretty “ambitious “ though. Probably more like 480m?
Dalamar
The throw won’t be much more than a ROT66 (15 deg tir), while technically those numbers aren’t entirely wrong, I’d say max usable is around 60 yards.. maybe up to 100 on turbo with a scope. Double that for for the low cri garbage like xpl
Candela is the only meaningful metric, and this won’t have much.
Favorite lights:
Lojik
Lojik's picture
Last seen: 1 hour 4 min ago
Same here. People are just finding the dumbest shit to knock Fireflies. My E12R is THEE literal shit.
Many other lights have super minor and trivial issues yet nobody brings them up like people like to do with Fireflies.
Fireflies hit nothing but home runs in their newest line-ups. And I don’t see that changing anytime soon with the even better direction they are going in. The driver alone is a panty-dropper, but the emitter options are killer too.
Don’t worry about Fireflies, so many top companies put out faulty lights here and there. The on only real issue I’ve seen in any new FF is someone’s LED’s weren’t turning on. That is a real and legitimate issue unlike the many people whining about nothing. But either way that’s just one of hundreds if not thousands already sold that has had that single issue. Anyway, if you do end up getting the rare bad light, FF will take care of it. And if they don’t, make sure you pay with PayPal and they got you protected.
Fireflies is a top company. If you look around you’ll find plenty of Hank lights or Sofirn’s or Convoy’s that have had random issues too. It is what it is with lights from China. But none of them have the swag of Fireflies, they just keep pushing the envelope and I love em for it. Fear not, chances are you’ll get an amazing light instead of a dud.
Dalamar
Fireflies poor communication and refusal to sell parts separately is never acceptable anywhere. Right to repair should be mandatory and universal. I also think I shouldn’t have to file or sand anything – certainly don’t need to with Hank lights, or even Convoy.
If their new USA dealer is going to cover for them repairs wise, then it’s a lot less bad. But I suspect they won’t.
The host thread issue is potentially massive. The threads on these new lights seem kinda poor. Once you wear them out the host is useless, and the host is the most expensive part of the light generally. Additionally – try replacing the oring on the nov-mu after taking the glass off. You’ll spend HOURS trying to get the end screwed back on with the oring staying put…It feels like they don’t want people to repair..
The only thing I’ll agree with you on is that MOST of their problems are just a minor annoyance. The ones above are NOT, and is literally what keeps them from getting the Hank Hype. I usually end up swapping batts in a few lights every camping trip, the one I use on coons only gets ~40 min runtime. I think it’s perfectly reasonable expectation for an aluminum host to last practically a lifetime. But with the new round of hosts, I have doubts.
EDIT: and don’t take it as knocking FF. I think Lumintop is even worse. I couldn’t attempt to contact them at all – fake email that bounces back at you. They won’t get a dime from me. FF’s contact problem is rubbing me in a very wrong way, but they’re also selling something a little more unique than Lumintop or other companies only catering to the low cri stupidity
Companies should strive to at least sell you the parts for repair, and tell you how not to kill USBC charging ports (because there is no standard in chargers etc). And states should all mandate the right to repair, not this corporatist “just throw it out and buy new one” nonsense
Favorite lights:
