Test/review of Vapcell AA 1800mAh P1418A (Black-Orange) 2020
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 4 hours ago
DSC_3486
Official specifications:
  • Size: ø 14.2mm x 50.2mm
  • Nominal voltage: Constant 1.50V +/- 0.02V
  • Typical capacity: 1800mAh
  • Minimum capacity: 1700mAh
  • Weight: Max. 22g
  • Charge by USB: 5V 350mA +/- 50mA
  • Over current protection: 2-3A
  • Maximum continuous discharge current: 1500mA
  • Build in battery: LiIon INR14430 920mAh 3.6V
Vapcell%20AA%201800mAh%20P1418A%20(Black-Orange)%202020-info
This is a USB charged LiIon backed 1.5V cell with a build-in buck converter to step voltage down.
DSC_3485
DSC_3487 DSC_3488
DSC_3489
DSC_3490
DSC_3491
DSC_3494
Vapcell%20AA%201800mAh%20P1418A%20(Black-Orange)%202020-Capacity
This type of cell has a very stable output voltage independent of load up to the limit. The two cells has slightly different capacity.
The A 0.2A curve is due to a failed charge. At 2A the battery shuts down and recovers constantly.
Vapcell%20AA%201800mAh%20P1418A%20(Black-Orange)%202020-CapacityTime
Vapcell%20AA%201800mAh%20P1418A%20(Black-Orange)%202020-CapacityTimeHours
Vapcell%20AA%201800mAh%20P1418A%20(Black-Orange)%202020-Energy
Vapcell%20AA%201800mAh%20P1418A%20%28Black-Orange%29%202020%20load%20sweep
The battery can deliver about 1.8A, then it will shut down.
USB%20Charge%20Test%2020210308180336
This charge test is done much later than the other tests and the battery has not been charged in that period. This means it was completely empty and the cell must have been damaged due to that.
Conclusion
The cells works fine as 1.5V USB charged batteries. The maximum output current is fine compared to alkaline batteries, but cannot match a NiMH battery.
Also, the battery cannot be stored for prolonged periods, it must be charged at regular intervals, this will be the case for all LiIon based 1.5V batteries.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
d_t_a
Last seen: 5 hours 49 min ago
Thanks for this review, HKJ! I’ve wanted to know how this battery performs for some time now.
I do have some questions:
In your information table — [Discharge current — Capacity mAh — Energy mWh]
0.2A 1996mAh 2967mWh
0.5A 2325mAh 2354mWh
1.0A 1737mAh 2584mWh
Is the information for 0.5A correct? 2325mAh (at around 1.5v) but only 2354mWh?
I’ve tried using SkyRC MC3000 to discharge a just-fully-charged Vapcell P1418A at -0.50A and got around 1928mAh before it dropped to 0-volt.
(I understand the MC3000 wouldn’t be that accurate. compared to more professional test equipment..)
Another question:
Is the “USB charging” graph started from when the battery is Empty? (I think probably not, because only “288mAh” capacity was charged).
I tested how long it took to charge a fully-drained P1418A, and it took a bit over 3 hours.
(using EBD-USB+ meter at the USB source voltage side)
HKJ
HKJ's picture
No, I made a typo transfering results from my test log to the spreadsheet, it is fixed now.
Sadly yes, but the battery had been in storage for some time and discharged totally, this had damaged the cell.
