I’m too lazy to take and upload a picture - but I checked, and the google image search result for “hard drive magnets” is pretty representative. I have varieties from both desktop (3.5”) and notebook (2.5”) hard drives.
Here are a couple. Often the holder has bends in it and makes it less handy to play with.
You can pry the magnets off the plates, but the magnets are way brittle and I often end up breaking one when doing this.
If you want a really strong magnet to play with, seek out an old 5.25” floppy drive - one of the early ones. They have a circular magnet that was used in the motor. So strong, it’s difficult to remove one from a fridge without divine intervention.
I’ve used the HD magnets to make clasps for woodworking projects. Good for holding “stuff” in place when a third hand is needed.
Scallywag, I’ve also been collecting HD platters. I started when clients needed a data wipe on a drive that wouldn’t spin. Pulled the platters rather than smashing or drilling.
Not sure why I started putting the platters in a drawer after hitting then with the degausser, but there I go again collection “stuff”.
Some of the platters are more silver colored. They make great first surface mirrors as they are VERY flat.
For some reason I also stared stacking old CD disks from software releases Etc. Stuck a dowel in a hunk of wood and started piling them up. About 3’ tall by now.
For those interested in harvesting HD magnets, you will need a few smaller Torx drive screwdrivers. Be sure to look under labels for hidden fasteners.
Good quality stainless steel screws and aluminum (from the chassis) for recycling if you are so inclined.
All the Best,
Jeff
Yup. I have one of the $25 iFixit miniature screwdriver sets (well, it was $25 when I bought it, $35 here ) and it’s all I need for the screws. Some of the labels/stickers are a bit tough on just fingernails, so I’d recommend some kind of metallic spudger tool for those. As mentioned the magnets are quite strong so have fun with ferrous-metal tools occasionally snapping over to the magnets :+1:
The best platter I almost had showed significant head-crash damage. Along the inner half-inch the coating was mostly completely removed (some rings here and there remained). However, that platter technically belonged to an old employer and had to go to their secure data destruction procedures… (they drilled holes in the platters). My plan for my shiny platters is to mount them all in a frame as a cute artsy “mirror”.
That’s cool re: 5.25” floppy drives. I’m not old enough to have ever used one myself, though I’ve encountered them (and the actual floppy floppy disks) as scrap occasionally over the years.
salvaging magnets from old tech was something we did for several years.
now, we check out the recyclers on Craig’s List when we need some more.
regarding mirror-like platters: we used the hole as an aiming device
for signaling in Cub/Boy Scouts. it was harder to do as opposed to
using a dedicated signal mirror, but it can and was done.
fragility forbid inclusion in our load-outs.
Forgive my ignorance, it can be harm to the eyes look direct a Led driven by about 5 mA but with PWM?
the driver is AMC 4*7135.
A friend ask me if there will be eyes issues with PWM.
I don’t think it makes any difference if the LED is PWM controlled or current controlled as far as looking at it is concerned.
Too bright is too bright no matter how you get there.
As Scallywag said, a too slow PWM coupled with a short duty cycle makes for a very unpleasant light to use in almost any circumstances.
Some lights have truly awful PWM running in the 100Hz to 300Hz range with 5% to 25% duty cycles.
One of these will cause eyestrain and headaches for me and many individuals. Yet some folks seem immune to truly awful PWM.
There are several threads about PWM that are buried in the general info category.
I made a video of the LT1 PWM charactistics and duty cycle here:
That might help explain the relation of PWM to brightness.
And another looking at PWM vs camera shutter speed.
CNCman,
PWM and the duty cycle is baked into the firmware.
So unless you can get hold of the code and flash the driver you are stuck with the OEM settings.
In another thread TK told me that the 5K PWM at the lowest levels was to provide enough ” on time” pulse to light the LED.
I (think) I can detect PWM into 3K realms if the conditions are right.
Total dark and spinning fan blades that I can vary the RPMs.
5K and up and I’m good.
All the Best,
Jeff
Is it possible to modify a Halogen light bulb spotlight to use a XHP 70.2 led. I am concerned the reflector is not designed correctly for a led.
A good friend uses a cheap Q beam on his early morning fishing trips in his Bay boat to navigate to open waters. I thought maybe it could be improved since he is disappointed in its output. I wanted to dig into it since my operating table is vacant.
Yeah, most likely the reflector is not shaped correctly for an LED. Think about where the light is being emitted in each case - and therefore where the reflector’s focal point should be. For an LED, it’s almost exactly at the bottom of the parabola. For a halogen bulb, it’s going to be some distance inside the reflector.
I have seen several Surefire lights that include a clip that makes it go bezel up when stored in pocket. What are the practical uses for such a configuration?
I know for some small lights you can clip to your hat and use as a pseudo headlamp but what of larger lights?
