Is this the right place to get them? I just click the number, 247 at the moment, and then click download tarball
I guess I have to add those lines in if they’re not they’re already?
On another note, how do you guys bring the spaghetti monster files into a project? Do you just copy paste into the project’s folder? I’m not sure how to open anduril in atmel studio as a project so I can build natively in atmel.
The old guides I could find on blf have lost their images/are out of date
I have been looking for a source code of this 7135 driver: 淘宝网 - 淘!我喜欢
5modes: Low-Medium-High ,Recycling; Double-Click at any mode turn to strobe mode; Three times Click at any mode enters into stepless dimming mode (In the current state, the brightness first decreases and then rises. When it reaches lowest or highest, it will flash once and wait for 1 second to continue to increase or decrease. When it is turned off at any time in the stepless dimming state, the brightness at the time of shutdown can be saved.)
So far I haven’t found the code. Does it even exist in this repository?
I would like to modify it with a few elements of TK’s crescendo firmware. For example, I don’t need strobo, but I would definitely use battery check instead.
I’m not an expert, but I believe Crescendo is designed to be used on attiny 13A, 25, 45 or 85 MCU’s. (on the 13A there are reduced features) Those are all 8 pin devices. The driver pictured appears to have 10 pins. I don’t have any idea what that is but my guess is that it might not be easy to get crescendo to run on that MCU. Chances are there is no open source code for the firmware on that driver, but I am guessing.
Oh,I didn’t spot it had 10 pins. I thought all of the 7135 drivers are attinys. Too bad, I have already ordered a couple of those. Maybe I can live with them, but i will surely miss battcheck.
Hey I’m sorry if this isn’t the right place to ask this. If it isn’t, please direct me to the correct place. But I was wondering if someone could make a custom anduril mod for me?
Yes, I just want a hex file that I can flash to my d4v2. And I just want some of the strobe modes removed, and one strobe mode modified. I will pay for the services btw.
Question…
Is this the place where I can write or suggest modifications about anduril 2 or there is an other thread? (Like “Anduril…2?” By Toykeeper)
I want to help but I desire I am in the right position
Thanks
can someone help me?
I have an older (2 years) anduril hex file from Lexel for his Skilhunt H03 or Utorch C8F driver. I wanted to flash it to a Nangj 105c with Attiny 85 and tripple Channel Setup.
Can someone say me the pinout of this Anduril from Lexel? Is it dual channel or trippel channel? On which pin can I connect which output.
For test I have already disconnected the AMCs of the 105c on pin 6.
I have made several test but the flashlight works very unnormal, sometimes dark, sometimes with wrong order of channels.
Second Question:
Whats an easy driver mod? Using a A17DD (Astrolux S41) Driver, flashing Narsil and put the switch on the place of the OTC?
A Nangj 105c w/85 and triple channels? Really? A 105c is a ATTiny13a single channel, so how was this accomplished?
You have to go apples-apples: the .HEX file must match the exact pinout configuration of the driver, for one thing. There are a few possible I/O pin assignments for triples - I've probably configured them all, even modded Anduril and Anduril2 to support them. So we need far more details.
You got 5 I/O pins available:
pin #2 - usually switch
pin #3 - usually the aux/switch LED but also can be a FET channel
pin #5 - can be the single 7135 or bank
pin #6 - can be the single 7135 or bank
pin #7 - can be the voltage divider, or aux/switch LED, or a channel
What I/O pin config was the .HEX file built for, and what is the I/O pin config of the modded Nangj?
The A17DD with the ATtiny25 cannot run Narsil - you need a 85, plus another mod of adding the 4.7 ohm resistor on V+ input, least that's the mod I would do.
I used a 3535 MCPCB for the FET and the single 7135.
I dont Know. I am not able to build Anduril Hex files. For easy drivers I did it with STAR_momentary.
Lexel is cast away and does not answer. He built the Hex-File for his drivers (C8F or Skilhunt H03).
Thats the Problem.
For the 105c, I probably have to change some resistors too. But Pin #7 is the voltage divider on the 105c. But Lexels driver has 4 Outputs, the 3 channels and the switch-LED. I know this, because my C8F blinks out the channel with one, two or three blinks, after setting a brightness.
The 105c is not modded yet, I only connected the stars to the switch and new channels (FET and 7135). And I disconnedted the 7135 bank on pin #6 to test this pin with the FET.
Ok, think I mis-understood. I'm not familiar with his C8F and H03 drivers. I would convert to a simple FET+1 and use a D4 .hex file. I think the std FET+1 is the 7135 on Pin #5 and FET on pin #6. Don't need the voltage dividers because Anduril uses the internal method, usually that is.
I’m not really well-versed in the Anduril programming files, but based on the version check for the FWAA (I got the Nichia 219C and SST20 versions only; I’m unable to chance upon the always-out-of-stock XP-G3 version of FWAA) — the Anduril 2 version check will blink out firmware version 2020-09-27 model code ‘312’, which when cross-referencing to the “MODELS” file in Toykeeper’s Anduril 2 repository, this is the “FW3A-219” variant of Anduril 2.
I suppose that means going to the Anduril program code repository, and find the configuration file for “FW3A-219” and maybe tweak that? (sorry, I’m also unfamiliar with these code, I’ve not tried to compile .hex files yet…)
