Is this light using anduril 2? Otherwise anduril 1 should have the thermal config after 4 clicks iirc
Thank. Got it already, empirically.
Wow, I love the beam and tint, hhmmmm. Saw someone else post about how they liked the beam of this optic and was think'n the same thing. I got lots of multi-LED SST-40's and XHP50.2's way brighter, but this light for me hits the spot with a nice clean spot, not crazy heat, and I'm not noticing the green I guess. I'm using the Vapcell T50 with this light and it's outstanding. Granted, it's not the good SST-20 3500K quality, but for a 5000K, it's better than other 5000K LED's I got.
For me, the 351D 4000K sliced, XPL-HI V2 5D, and the good SST-20 3500K are about the best.
Of course I got Anduril 2 loaded, fully calibrated for temp and voltage.
Isn’t 50T too much for a direct drive SST? I think this is exactly the option: you even connect a nuclear power plant, anyway, a diode greater than 9A will not accept …
Dunno off hand, it works well for me. Think I measured in the ~9 amp range and got a good reflow, good MX-4 grease, etc.
I just glow for a while after turbo A Vapcell T50 is supposedly a Samsung 50S.
By the way, on my substrate is not copper, brass, although 2mm thick.
In general, I do not like SST 5000K in this optics. I will put XHP50.2 3000K. Only now I think: to dedomite or not?
Is the xhp50 3000k 6v or no? Are you planning on a new driver?
What is substrate? The XHP50.2 3V does not come in 3000K, so is it a 6V LED?
Yes, it’s 2mm, but I’m pretty sure it’s red copper in mine. I polished it to make it smoother. Unfortunately, there is no 3V XHP50.2 warmer than 5000K. At present, it is currently only available around 6000K.
I’d like to see with CULPM1.TG.
Guys Beriled argue that there is: Светодиод Cree 3V XHP50.2 New - 551 руб.
I have brass. I can take a picture, but you can take my word for it. I had something to do with metalworking.
Are you talking about the MCPCB??? Don't know why you are not answering my questions.
If so, from 2012, I've never seen or heard of a brass MCPCB - ever. It's thermal conductivity is worse than aluminum, it would be a mistake and tragedy, to say the least.
Some copper MCPCB's, like Hank's Noctigons, have gold plating on the bottom that has the same color as brass - maybe that's why?
The photo is not very good, but I think it’s clear: what is it …
Yep, the pink sides looks like copper to me. The bottom is oxidized copper - it cleans up with some sanding.
Yes, you are right, I polished it and everything fell into place. But you can also see why I was wrong. The color of the patina is exactly the same as that of brass. Compare the brushed side with the edge color and the other copper base color:
XHP50.2 LEDs
Look at the chart on page 5.
The store you linked to probably uploaded the product wrong.
Red copper is such color. The picture shows a raw PCB below it.
I can understand the confusion - no problem, good you got it settled.
Yes, I myself am glad that this is not so. I would not like to think about such a ridiculous substitution. Such powerful lanterns will burn like candles. Reputation worries should outweigh petty gains.
Somewhere on this site I read that maybe the AMC7135 is causing the high parasitic drain. I removed it and still have high consumption.
I received my EA01 replacement head and the parasitic drain is lower now, about 50 microamps. It also seems brighter than the first head for some reason.
What about the charging circuit?
