Charger for 10440 battery
12 posts / 0 new
nobody
Last seen: 1 day 4 hours ago
Just got some 10440 batteries.  Now I need a charger.  The one I have only does .5 amp.  Need a recommendation for a relatively cheap charger to do the job.  Thanks in advance.
ChrisGarrett
ChrisGarrett's picture
Last seen: 11 hours 7 min ago
Opus BT 3100/3400, or an Xtar XP1 Hummingbird.
Chris
nobody
Thanks.  The xtar looks good and is in the right price range.
ChrisGarrett
It won’t do anything bigger than an AA/14500 and while out of production, it’s inexpensive and it’ll do 250mA/500mA.
I have four of them and use them often, since I’m a 16340 lipstick light kind of guy.
Chris
bilakos10
bilakos10's picture
Last seen: 6 hours 15 min ago
If I were in your shoes, I would probably invest a few more bucks in order to get an all-around charger - one that's not tied to a specific cell size and/or chemistry.
You're in BLF after all. Getting your hands on other battery sizes and chemistries is just a matter of time  smile
ChrisGarrett
Robin Dobbie wrote:
What’s the ideal 10440 charge current? 100mA?
200mA-250mA is pretty benign.
Most are labeled 300-350mAh.
Chris
nobody
Already have some 18650 and 26650 with a charger for them, albeit a single cell charger, but it works fine - just doesn’t do .25A.
The little xtar sounds like it will do fine I think.
Agro
Agro's picture
Last seen: 11 sec ago
Most low discharge cells are rated to charge at 0.5C-1C. High discharge cells can do 1C or more.
Most 10440 cells are quite bad in terms of capacity and internal resistance as compared to larger cells, so I would be quite careful with them.
So I would recommend no more than 150 mA for 10440 unless you know it can be charged faster.
nobody
Agro wrote:
Most low discharge cells are rated to charge at 0.5C-1C. High discharge cells can do 1C or more. Most 10440 cells are quite bad in terms of capacity and internal resistance as compared to larger cells, so I would be quite careful with them. So I would recommend no more than 150 mA for 10440 unless you know it can be charged faster.
How do I know?  This cell came with my ReyLight purchase and the only information I have on the cell is the label — Li-10440 320mAH 3.7V
What charger will do the rate you suggest?
Agro
Agro's picture
0.5C. 160 mA.
Or less if you want to reduce battery wear.
If you can’t find a slow enough charger, you may try more, up to 320 mA on the first try. But be careful to monitor cell temperature during the charge. If it stays mildly warm, that’s OK. If it gets hot, that’s not OK. Do note that even if it gets hot but not very much, it doesn’t mean it’s OK. The cell will wear over its lifetime and its internal resistance will increase. And so – charging temperature will increase as well.
old4570
Last seen: 3 weeks 2 days ago
Finding a charger bellow 250mAh charge rate ?
If it’s a smart ( true smart ) charger , it wont hit 250mAh if the internal resistance is high ( one hopes )
those 10440 are very ?? , and ideally you would want to charge them @ 100mAh .
These days I slow charge my batteries .
The heat test !
Hard used batteries get warm / hot . Heat is a sign of stress ! The hotter the battery / the more stress it suffered . If you batteries come off warm / hot off the charger , then they were stressed again . This is why I slow charge my batteries , I don’t want to stress them while they are charging . Need a freshly charge battery ? Buy some more ! That way you can slow charge them and have them last longer and be safer . How long can a 18650 last – I have some that are over a decade old now . I should probably recycle my battery collection and just buy some new ones . Actually I might just do that 2021 . I have some chargers on the way for review , so I need some 18650 to charge .. But after that .
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Scallywag
Scallywag's picture
Last seen: 12 hours 46 min ago
I have a charger CRX custom built… it’s little more than a micro-USB charging circuit configured for very low current. He included it with a light that used 10250 cells, and while the leads are short, I extend them to charge my 10440s. Alternately, I can pop them in my DQG Hobi+ with extension tube to charge a 10440.
So the cheapest option for very low charge rates might be a properly configured small micro-USB charge circuit board!
