I read a topic about this flashlight and for BLF member it should be 27.70$ (or it was months ago). I will try to buy it with discount maybe, which one will give me better throw?
I just use a single one of these over the top just don’t do this on the head in case it delivers too much current. Using the 30Q I measured 8.4A at turn on, the LED peaks at around 9.4 ish so 8.5A is fine. I’ve sold plenty and haven’t had a single issue. Not sure what you’d use for the 21700 though
I will add that the only reason I have dual springs is because it’s a gun light, stops the battery disconnecting with the recoil. A single one of those springs would be enough.
Installed a BeCu spring I got from BlueSwordM in the Sofirn C8F and that Convoy spring performed the same in it, so you should only need the single spring
Sweet never looked at that one because it had SST40 on it.
Now just need to go order all the parts thanks for all your help. Nothing better than a light that can work so hard you can blow the LED up in it love it.
I already have it in KP CSLPM1.F1 green but don’t really like the green. I will be swapping the driver & LED out with Funtastic suggestion. It’s very easy to do if you have a solder iron. I just built a S11 XHP70.2 did not relies it was so easy.
I also have the 8A C8+ Osram CULPM1 great light. The M21B is a perfect size and I prefer the 21700 cells.
