【ツ】Wurkkos DL70 Teaser [coming soon]
What i really like is the dual battery setup,great autonomy I bet, and under water you get long time turbo :open_mouth:
I’m not too familiar with buck drivers, but 13,000 lumens would still deplete them in no time. Also no idea whether the water would keep it cool enough to stop it stepping down
I’m comparing It to the single battery Fet driven quad xhp flashlights, i think there Will be timed and thermal stepdown,but under water you still get stable output in High mode
I did a run time chart of the 3000 lm Sofirn SD05, with the light underwater (an awkward setup). It only stepped down due to the unregulated driver and cell voltage dropping.
13,000 lumens is a lot but I wouldn’t be surprised if it can sustain at least half that until the cells are empty.
Hopefully someone will review this and put it to the test.
The SD05 was a solid performer, shame they’re now using the old driver with the SST70, it has a timed step down after about a minute
Yes, same UI as in DL40. No timed stepdown but ATR with a threshold set to 55°C. XHP50.2 was told to be around 5.500K, so not as coldwhite as you might expect.
Well, in order to actually perceive twice the brightness of 4000lm you would need to multiply that number by four, i.e. 16000lm. So, 13000lm of the Turbo mode is quite close to being twice as bright as High mode. It will get interesting to see at what output this model will settle at 20°C on air or submerged in water.
Yeah, I just meant for a longer run before stepping down, sometimes only a small amount brighter for longer is better than max
Agreed, I will forward your suggestion to Mark. But I fear it is too late already to incorporate a mode in between of High and Turbo. Production has already commenced.
:person_with_crown: :person_with_crown:
Better be using top tier high drain 26650s here… I don’t like the looks of this one with the choice of cell format and 4*50.2.
Oooh, that looks nice!
I sense another winner!
Naw, all the steps are a nice consistent ~3:1, no big jumps.
This is one case where I’d be more comfortable with protected cells in series. :laughing:
Wonder what’s the current draw in top gear. They’d need to handle at least that much.
The PLB cells Sofirn stocks can handle 20A CDR, but datasheet says 10A max. I tested at 20A and it handled it nicely while only reaching 70°C. Beats most 5000mAh 26650’s out there
Hopefully the driver restricts the current draw to safe levels. But two 50.2s per cell would be a ton of current and too much for anything but maybe a Golisi gold, and likely still at dangerous levels. The ATR should at least intervene and keep the cells safe in air. IDK about underwater.
Another thing to consider with CDR ratings is cell aging. IR goes up with cycles and therefore temperature rise. Abuse the cells repetitively and it can get ugly sooner than you might expect. 5mOhm extra IR can equal tens of degrees C
The Wurkkos DL70 has been listed in Wurkkos.com website
and also in Sofirn's/AliExpress store
Interestingly, I notice a couple of new Wurkkos "DL" diving series flashlights, which doesn't seem to be mentioned yet:
1) Wurkkos DL10R = uses a single XHP70.2 LED ~ 5000k, uses 1x21700 battery, with Low-Med-High magnetic control ring.
(I guess this makes it the "higher brightness but a bit more floody" version of the Sofirn SD05)
2) Wurkkos DL07 = this looks interesting, as it appears to be a re-purposed Wurkkos WK30 -- it uses 1x 26650 battery
( I mention a 're-purposed' WK30 since the WK30 uses 1x LH351D 5000k, 1x LG UV365, 1x XPE red )
the description of the DL07 indicates it has: 4x LH351D 5000k, 1x LG UV365, 1x XPE red; plus 1x XPL-Hi
*specs on the site are incomplete, there's mention of "1000" lumens but unsure if this just refers to the XPL-Hi, or also the 4x LH351D..
The DL70 appears to be the brighter version of the DL40, since both the DL70 and DL40 use 2x 26650 battery and uses 4 LEDs..
the DL40 uses 4x LH351D 5000k whereas the DL70 uses 4x XHP50.2.
DL70 ready stock on Amazon now, 40% off code for BLFers
The main different of DL10R is come with directly USB-C charging port inside the tail switch
I’m not located in the USA (I’m in the Philippines) and am not able to order from Amazon.com
Any discount code available if I purchase from wurrkos.com or Sofirn/AliExpress store?
