Thanks Simon. Sorry for bothering you. I hope, you’ll announce here when driver is ready.
Simon Mao: Alex5542:Hey Simon ! How does the production of GT driver for SBT90.2 go ?
SBT90.2 driver for L6 and 4X18A are all in production ,but i’m not sure the completion date ,yet
Okay, I will.
Simon, you made an 18350 pipe for C8 +. That’s good! Are you planning to make an 18350 pipe for the M1?
The sales of M1 are too small, so I don’t have this plan for the time being.
I belive the sales of M1 are small because there are no any emitter options.
The only option now is xpl-hi. I would be interested in some hi-cri options like sst20 or lh351d or an osram emitter for a small throwy flashlight.
I think its a very nice design with more thermal mass and throw than a s2+ but not as bulky as c8+.
There are so many emitter options for the bigger 21700 M21b but none for the 18650 M1. Same thing was with T2
Simon, are you going to sell the SFT-40 LED and if so when will it be available?
I’ve asked this recently and Simon said it will be soon. Few weeks or less. I’m waiting for this LED and the SFT-70 with much anticipation. I plan on doing output testing immediately once I receive them and posting results comparing to HX, SST40, and others.
Will the C8+ 18350 tube work with the original C8?
Is the thread form of the C8+ the same as the original C8?
My supplier first said “early April”, then “mid-April”, and now told me “late April”.Oh ,damn…. I am very melancholy.
Simon Mao:The sales of M1 are too small, so I don’t have this plan for the time being.
I am very hesitant.
Because more and more buyers will choose 21700 flashlight
suitable
Simon, what’s the UI on this new L6 driver kit (FC40)?
US $17.30 | Kit (GT-FC40 + Driver + Switch) for L6
https://a.aliexpress.com/_mK0CtvN
淘宝网 - 淘!我喜欢
Mode: 1–10–40–100 (Double click side switch ——> strobe),max output 4amps
Simon when for a 3A version of your 17mm mosfet linear driver?
I like them,single side,efficiency than AMC based
A sense resistor mod should allow 3A to be easily achieved.
I mentioned that in another thread. A 3A version would be compatible with most LEDs, and single sided drivers fit the pill in an S2+ using the retaining ring. Simon has an updated 3A driver but it’s the same 7135x8 driver from before with the newer 12 group firmware.
Sari33:Simon when for a 3A version of your 17mm mosfet linear driver?
I like them,single side,efficiency than AMC basedI mentioned that in another thread. A 3A version would be compatible with most LEDs, and single sided drivers fit the pill in an S2+ using the retaining ring. Simon has an updated 3A driver but it’s the same 7135x8 driver from before with the newer 12 group firmware.
I agree,glad I’m not alone.
From a Mosfet driver 3A is a good amount of current for many single Led 3535 size,where 5A mean many more heat.
Yes single sides perfect to be screwed on S2+ pill.
And the efficiency Is better at lower levels current than AMC
Hope to buy It soon
jasontheguitarist: Sari33:Simon when for a 3A version of your 17mm mosfet linear driver?
Hope to buy It soon
This is 3A driver ,it has constant current and temp control. how about this?
Seem different layout with a lot of resistors, is affordable? Was enough get 3A by change the R010 sense resistor from the stock 3V 5A Driver?
Guys, i need your help to determine what resistor to order for purpose of lowering max output. Driver is 17mm 5A 12group and i would need 4A and 3A (have 3ea). I meassured resistor dimenssions 3.35x2.65mm roughly and written R010 which gives 5000mA now. The story behind is that i’ve got colored S2+ Osrams and green is running great but yellow-orange and especially blue Osram is going to fry. My idea was to lower amps on blue to 3A and on amber to 4A instead of 5A originally. [image]
Wish It came also with “Biscotti” FW
[quote=Simon Mao]
This is 3A driver ,it has constant current and temp control. how about this? !https://live.staticflickr.com/65535/51120102569_cc4328b736_b.jpg! !https://live.staticflickr.com/65535/51119781942_35109f3274_b.jpg!
Awesome!
