Please do :innocent: We’d all love to hear it I’m sure! Every last miniscule and silly detail. (ha! okay, maybe I should speak for myself…)
As sunnysunsun commented, my immediate thought was adding surface area to the radiating surface of the PW. Also, at these temps, radiant dissipation isn’t anything to snuff at, so anodizing the aluminum plate should help cooling too (dye not necessary) as Al2O3 has much higher emissivity than Al. The natural oxide layer is too thin to behave like alumina.
Another thought is using a collar in conjunction with the wheel. Mounting will be extra difficult, but I don’t see why it wouldn’t behave the same as with a static phosphor. — I’m imagining this mounting to a shield covering the cooling/off-center portion that should reduce a boat load of spill artifacts too. This front (inner? recoil design makes this a bit ambiguous) shield can also contain additional forced air ducts/fans.
So many orders of magnitude from anything most of us have ever seen, it’s crazy to think that there will be more light loss in the lens than many flashlights even make.
I have so many thoughts and questions. Can’t wait for beamshots but I’m 100% positive they won’t do it 10% justice.
I wish I had the time and money to build stuff like that!
You’re basically combining all the best features, LEP, phosphor wheels, recoil reflectors, and liquid cooling.
Is the reflector glass or electroformed?
I had some issues with my first electroformed reflector, eve the slightest wire pushing on it would cause deformation.
Mounting it without distorting the parabola is difficult, so I ordered mine with a mount preinstalled.
WOW !! that project is very expensive !!
Congrats for Millionaire to have such a project to share with us.
What an engineering task that is plan and build. Great job !!
Are you an Electrical or Mechanical Engineer ?
Thanks for all the interest on my project. Feel free to ask again if I missed your question.
It would be great discussion if anyone can point out things that can be done more efficiently.
I have two NUBM31T (90W each @ 445nm) diode banks in the system. While operation at 90W output, it will draw about 270W input.
There was a great deal of ideas to approach on cooling the phosphor. Some methods required a great deal of back clearance for a heatsink. They also offered turbines in the back.
Most of these methods was not very space or dust conscious.
The fan version would eventually get the chamber hot as it is just mixing hot air and the aluminum extrusions may expand due to heat and I would loose the alignment of the two diode arrays. The heatsink method required a CNC block of aluminum which I really wanted to do. I would have looked very nice and would protrude out of a hole on the front lens, but it took up too much back clearance for my liking.
I finally opted for the filtered and pushed air to solve two issues. Actively cool PW and expel the hot air our of the system. As the air exits, it will pass by the aluminum and slightly by the optics to keep things cool. I also wanted to maintain positive pressure to keep everything nice and dust free so I used HEPA filter.
I was able to order a wheel with airfoils on the surface which could squeeze out another 10~20W of laser power.
I always wanted to be on that list haha. I was directly inspired by all of you back when I was playing with XPG2s and gasoline.
150Mcd would be amazing!! I am running past the manufacturer specs so I wouldn’t really know what can happen. It will take some time to perfectly align the two diode arrays. I have designed a 1-axis swivel mount for the mirrors, but I still need to align the other axis and the distance of the laser array from the PW.
Everything is so compact, I cant get my thermal camera at a angle to read the phosphor wheel. I would be doing lux meter testing and watching until the curve starts to taper flat as my indicator that it has reached maximum.
Collars are magical little things. I’m surprised every time I play with one. I tried so hard to find a way to jam a collar into this design.
While using Enderman’s calculators I realized, collar + recoil designs are not very volume conscious. They take up so much volumetric space and my box would turn into a long boi.
It may not be the right place to bring it up, but I have spent an unimaginable amount of time contacting like 8 optics manufacturers in China to source collars, and also the parabolic mirror used in this project that is made out of glass. (The parabolic mirror I used here is aluminum)
If anyone is interested, it is possible to produce collars for 7USD each, 800pcs MOQ. They can make 60deg and 80deg apertures. The wavien patent is laughably weak. The patent is only valid if you sell a system with:
collar + FOUR OR MORE leds in a light producing system.
If you sell a flashlight with ONE LED + collar you would be totally safe.
If you just sell a bowl shaped mirror with a hole in it, you are untouchable.
I greatly respect wavien for this idea so I wont do anything myself at the moment.
Thanks Enderman, your builds + calculators have directly inspired me to make something really fun.
Sadly, I was not able to source any glass parabolic optics.
Mine was kindly made by phoenix electroforms and even had a nice rectangle hole cut out for me.
I was considering how to mount it. The option that the suppler gave me was the RTV glue at the base. I didn’t like the rigidity of that design so I decided to make a much wider carbon fiber holder. I mounted it by 3D printing a perfect profile to mate with the parabolic profile and then VHB taped it down carefully. It is appears to be very rigid as it grabs on to the edge of the reflector now. I haven’t did much focus testing yet as I am still trying to position the laser spots correctly at the centers first. Everything was designed to be able to shift around a few millimeters, so I hope that would be enough to get it right.
They are all made for Xenon lights where the focal point is deep in the middle of the reflector. The lowest I was quoted was like $5000 to make one. Optics making is basically limited to molding and then final grinding because grinding is crazy expensive.
I didn’t know about the nubm34 until recently. I probably would have picked the nubm34 if I knew. It is a much smaller package! There are other options like the OSRAM stuff, but I compared the beam quality and NICHIA is way better.
Lollll. I just spend the money I make on projects. I have way more enjoyment building things than buying luxury things.
I was not able to finish jr college and transfer, very bad grades |: But during that time I learned how to contact China, make things, sell things, and make mistakes. I don’t know read or speak any mandarin so that was fun.
It seems like you’ve exhausted (ha pun) a lot of the possibilities of air cooling. Could something wilder like evaporative cooling with tiny squirts of 99% IPA onto the back of the disk be a possibility?
Haha I’m glad you’re making use of those calculators
You’re right, using a wavien collar in recoil configuration is very space inefficient, like a lens.
As for glass reflectors, a while ago I found a bunch of them show up on ebay, like this one 11" dia, Glass parabolic, reflector, mirror, searchlights, solar, entertainment | eBay
They have 11, 13, 16, and 20+ inch sizes. The focal point is in front of the reflector too, which would work for our LED/laser applications.
Unfortunately they weren’t available when I built the Syniosbeam, but I would have probably used the 11” one if they were.
I don’t know how accurate their parabola is, but it seems much better quality than the “solar concentrator” parabolic mirrors that some places sell, so it may be optical grade quality?
Also I saw you over on LPF (I don’t have an account there) talking on the NUBM31T thread haha
I am so very Happy for you likevvii to be in position to build a dream and have the will and perseverance to succeed.
There are many intelligent members here at BLF that will enjoy this project !
Thank You for sharing.
From memory:
There are 2 or more collar patents. One is for RGB (W?) LEDs and maybe that’s what you mention when you say about 4 LEDs?
There is a much more generic patent and it’s not easy to work around it.
