I’ve soldered mine, but have set ceiling ramp to approximately the original highest brightness.
Double click to turbo will do the full (modified) output, but I don’t like leaving the light unatended in turbo for fear it’ll get hot and fry the LED’s.
You see you need to pay attention and ‘be in the know’ with these cleverly designed lights. Many secrets lie within. It’s pretty cool I’m sitting half way across the world with my LT1 apart on my coffee table unlocking it’s hidden talent with direction straight from the horses mouth! (I don’t mean your a horse). But it’s good, got muh HB pencil & about to do surgery.
[quote=CR888
You see you need to pay attention and ‘be in the know’ with these cleverly designed lights. Many secrets lie within. It’s pretty cool I’m sitting half way across the world with my LT1 apart on my coffee table unlocking it’s hidden talent with direction straight from the horses mouth! (I don’t mean your a horse). But it’s good, got muh HB pencil & about to do surgery.[/quote]
-We built the LT1 to have a good balance of output and run time with its factory configurations. The extra 7135 chip pencil/solder mod is there for those who want to boost the output a little more in sacrifice of runtime. (keep in mind the head of the LT1 will also get hotter too.
It has 7 7135s which means 2.45A at the head. That’s about 7.5W of power and the LEDs turn some of that power into light. I have a 5W little usb heater with less surface area and its heating plate reaches about 80C when constantly on. The LT1 has more surface area to shed heat and the LEDs (probably?) turn more than 2.5w of that into light.
I did the pencil trick and noticed a reasonable difference but also it’s hard to tell unless you have a modded one next to a stock one. Worked good. I like my LT1 lantern. Used it tonight loading my truck with nice cut & split Redgum for my fire. Was thinking the other night, given the lt1 battery size/tube is similar to many pop can size lights a decent ‘optional extra’ could be a multi emitter head to convert it into a flashlight. But then again I thought if I had that I’d want an extra body tube!! Looking forward to the next generation mini when it comes out.
The Q8 is on the list I saw some beam shots which looked good. I receny had a blf36-pro arrive which is kinda similar, it’s a 3x18650 8k-lumen. Im a biqt of a sucker for Sofirn lights, for the money they are pretty good. What I’ve been trying to find is the right size collapsible silicon bowl to do what DBSAR did making a ‘shade’ cutting a whole the diameter of the LT1 fitting it to the top to direct light down/across. I also like being able to use 1-4 18650’s in the lamp, that’s clever.
I put 4000k LED’s in my Q8, I much prefer the tint! You can also get a nice plastic diffuser for the Q8, completely different to the LT1, but good for a “work light” or similar.
Re. Bowls, I think it’s one of those Chinese products that are all produced in the same factory. You’ll probably want a white one to avoid casting colourful light all around the room.
Theyre pretty cheap, 3-5 USD on ebay, they all look the same- they’re the ones with the black coloured, hard plastic rim, with a cheap and nasty carabina.
Black plastic rim can be carefully removed to help minimise pack volume.
Don’t cut the hole too small- mine is only just snug enough. I’ve taken the orange o-ring around the top off and the shade fits neatly in the groove.
Re. 1 to 4 cells, I know different folks have different views, but I’ve a couple of sets of 4 cells, which I specifically keep married together so they all behave the same and are always the same level of charge to avoid any problems… :+1:
