The K64's finally arrived at home - hope to charge them up this eve.
Update:
Charged up the cells, and based on the starting level and how much mAh's they took, the capacity sounds about right. They also performed well in running some simplistic tests, measuring initial amps on some higher powered single 26650 lights.
on a stock FT03 XHP50.2: K64 at 4.21v: 16.0A, GOLISI 26650 @4.21v: 14.5A
on a Emisar D4SV2: K64 at 4.21v: 16.9A, GOLISI 26650 @4.21v: 14.6A
on modded Haikelite HK4S: K64 at 4.21v: 21.2A, SHOCKLI 5500 @4.21v: 18.0A
on modded brass MF01 mini:K64 at 4.21v: 24.1A, 40T @4.20v: 25.0A
Still want to do capacity tests on my chargers, two SKYRC MC3000's. The GOLISI's are not new, but shouldn't be heavily used, but still may not be a valid comparison, and limited test of simple initial amps.
Appears so far to be a solid candidate for best all around 26650 cell, great capacity, excellent performance.
Thanks a lot for testing Tom E! I am surprised that K64 even surpasses the PLB 55A cell underneath the Shockli 5500 wrap, being so close to the power of a Samsung 40T. Since the 21700 battery makes more spring compression in the MF01 mini, the K64 battery could be even in line with the 40T if contact resistance is disregarded. This is fantastic news, especially since PLB once announced they would discontinue their 55A cell. :-) I look forward to seeing your capacity tests.
Maybe HKJ can also do some tests under heavy load (10A, 20A, 30A).
Is it still not possible to consolidate shipping fees on the Aliexpress store ? last time I asked they didnāt want to. So we have to pay 3.98USD of shipping per itemā¦
If I order 2x L10 shipping is 3.98, if I order 4x L10 itās 3.98, if I order 2x L10 + 2x H10 itās 7.96 even though itās the same weight as 4x L10.
Nice! My capacity testing may have to wait til the weekend. Let us know if you do any more testing.
For me in the US on the Ali store, if I buy, 4, 6, 8, or 10 K64's, I pay only $2.11 for shipping. NY State (and fed) sales tax is steep and Ali charges it, so for qty 4 and above, NYS sales tax is higher than shipping.
You don't have the same options on the Vapcell Ali store in the EU? Maybe this is a new option?
Granted, these are not cheap, for sure. For qty 6, it's a total of $67.37 total for me.
From 1x to 10x K64 the shipping is 3.98 here, but what I was talking about is when ordering different cells, letās say, 1x K64, 1x M11 (18350), 1x M35 (18650), then shipping is 3x3.98= 11.94, despite weighing way less than 10x K64.
And Vapcell doesnāt want to recalculate the shipping cost, unlike Simon/Convoy for example, if you order 10 different small items from him he will recalculate (if you ask him) an appropriate shipping cost instead of charging shipping for each item.
Doesn't sound fair, I see what you mean now. Think it's just easier for them - not 1 person can directly control each order charge like Simon can. Weight does matter but it's not a direct ratio with cost.
I received 2 pc K64 last week and one has 3,67v, the other one has 0,3v ... so one is dead on arrival.
I used the good one in D4sV2 and in Ni40 and it is very similar to the Shockli 5500 and I get round about 6000mAh into by a Start of 2,95 to 2,98v. So as my first resume the good one is a good Battery but do not reach more kapacity like the Shockli in the first attempts.
I would like to see, what Vapcell say to the DOA battery, but no answer yet now....
K64 is not available to order anymore. On TLF I noticed another member reporting that two out of two K64 batteries were dead on arrival with 0.7V and 0.74V.
I ordered 1lot(8pcs) Vapcell K64 from Vapcell/AliExpress store last April 3, 2021.
I was given this tracking number, but later changed to another tracking number:
RB635245138TW & RB753931767TW,
but both these tracking numbers do not show any infomation on tracking websites.
Did some simple tests last night, but not long timed testing. Just in initial amps on a FT02S (quad XHP50.2's) w/mods, all cells charged to 4.21V:
Shockli 5500: 22.8A
Vapcell K64: 26.4A
Samsung 40T: 30.5A
Vapcell T50: 31.0A
On a MF01 Mini, brass w/mods:
Vapcell K64: 24.1A
Vapcell T50: 27.2A
On a HK4S (quad SST-40) w/mods:
Vapcell K64: 21.2A
Shockli 5500: 18.0A
So the T50 is much it's superior, but the K64 does well against the Shockli. This is just turn on amps, somewhat indicative of what it can do, but an initial 30 sec test, plus a full timed run would be a better comparison.
