Keeppower 26650 5200mAh P2652U (Blue-white) 2020
Official specifications:
Voltage: 3.60V
Rated capacity: 5200mAh
Minimum Capacity: 5100mAh
Discharge cut-off voltage: 2.50V
Charge voltage: 4.20V +/- 0.05V
USB Charge voltage: 5V +/- 0.5V
Standard charge current: 1000mA
Maximum constant discharge current: 8A
A USB rechargeable LiIon 26650 battery from Keeppower.
The two cells tracks nicely and can deliver above 10A before the protection kicks in, capacity is nearly constant at all loads.
Conclusion
This is good looking 26650 batteries with good of capacity, protection and USB rechargeable
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
