Oh hope you find it soon. I had a similar situation just the other day. Was looking for my neodymium magnets for days everywhere and finally found it in my battery bin!
The 10440 tube is a great idea. I would get one right away. Hmmm I think I’ll go bug Sofirn about it!
I’m planning on making a 3D printed charger for 10180s but it’s going to take a while. I’m currently researching ways to sort out RPP since all these cheap little charging chips I’ve come across don’t have battery side polarity protection and I don’t want the charger to go up in smoke when you put the battery in backwards.
Should be ready in a few months time since this will be my first pcb design project and oshpark takes a while. Our local public library has 3D printers available to use which is great but I need to learn how to use 3-d modeling software first.
The 10180 is a novelty battery for a novelty light. Cool invention but it cannot be relied upon for emergency use. If your light has an electronic switch like the nano, the parasitic drain will likely eat up the battery while the light is in your pocket. When you need the light, guess what? You are screwed.
Great feed backs but I think I’ll just skip 10180 flashlights for now. I already have 2 chargers and I don’t what a third one. Plus If I use my Opus, it might ruin the little guy. Kind of like burned toast.
This is how I charge my 14250 batteries. I just add a magnet to the positive contact, put into my Opus BT-C3100, and charge at 200 milliamps. There should be minimal resistance since the magnet is solid metal.
Steve Ku of Veleno designs used to sell a “nano” charger for 10180 cells. I have one that I got with a quantum dd. USB charger and it works well… if you can find one.
Thanks for the idea! I’ll try to find a long cylindrical magnet (any idea if neodymium “rare-earth” magnets are good conductors or will add a big amount of electrical resistance?)
I suppose the electrical resistance is OK since most chargers may be charging at a bit higher current, and the resistance sort of lowers the charging current?
Of the roughly 45 lights I’ve bought in the last year I’ve luckily yet to need any of them in an ‘emergency situation’ but I get your point. I did however buy 5 extra 10180 batteries when I bought a L/top Nano as the shipping cost was more than a single cell, I think 5 was like $15aud. Also got the 10440 tube so maybe the Nano is right now for emergencies lol. But with a full battery it has quite a useful runtime even with the 10180 I couldn’t run the thing dry going for a 1/2 hour walk. I wonder what light is king of the ‘emergency situation’…I suppose it depends on the emergency.
Parasitic drain is a fair question, I’ve left my DQG fairy for long periods of time without charging it, I suspect that there is no parasitic drain.
Sofirn SC01 has a different mechanism (its a ‘screw the head off to access the charging port’ kind of light, I do not know whether this has parasitic drain…. anyone?
It’s not too demanding to keep it topped up at any rate, same charger for my phone so always have a cable.
The very faint red light is almost not visible when looking straight up.
Position the light a bit at an angle (and in a relatively dark place) to make the red light visible, such as shown in the picture below
(in actual, it’s not as bright as the picture shown below)
