Some years ago I asked this same question and was told to us compressed air so I went into my shop and grabbed my air compressor nozzle and gave my reflector a quick blast and did the most spectacular job of spraying water all over the reflector.
Hadn’t heard of cans of compressed air yet, I’ve never have made that mistake twice and I always drain my air compressor regularly, ha ha
Because I pissed off cleaning reflects, I stopped buy lights with bad sealing.
Mostly Convoy lights are not dust proof.
Prefer TIR optics and for reflector one buying some more expensive brands like Olight, Nitecore, etc.
Some Astrloux lights like ft02s, ec03, ea01s also has good sealing.
I think it’s pretty cools when someone resurrects an old thread! Some things are still relevant today as they were years ago.
I once left some smudges on an OP reflector after I tried to remove some lint. So I put it in an isopropyl alcohol bath, rubbed the same spots, and then blew it dry. Luckily it turned out great.
I’ve learned to blow air through the hole into the reflector to remove lint. And to use a very pointy toothpick to nudge any remaining lint.
I used to try microfiber cloth and ended leaving lint all over the reflector. I tired using alcohol and ended up taking the relective paint off of cheap lights.
Now I just used soapy water and rinse with clean water. Then make sure you don’t touch the reflector at this point and use compress air to dry it. I use a simple camera air bulb.
If you don’t see any artifacts in the beam profile, leave it alone, is what I’ve been told, since the vapor deposited aluminum is a very thin layer and easily damaged.
Now, if you’ve snotted out a slimy booger onto your reflector, get some distilled water and give it a shot.
Boogers will show up in the beam profile and that is absolutely soul crushing for many here.
Running water and soap foam (not normal soap) and your bare clean finger can work. Afterwards you need to wash it off with distilled water and let it dry. Don't use any cloths, they will easily scratch your reflector. In most cases it's best to not clean it at all. The chances of ruining it are high.
“Don’t use any cloths”… Hmmm… I will disagree with most guys here.
There are clothes - and “there are clothes” Super fine microfiber cloth will not damage reflector…. Fine microfiber cloths are used for super expensive 2000+ Euro riflescopes like Zeiss and Swarovski. For cleaning their lenses and AR coating on them(which is btw more sensitive than reflector) so it will definitely not scratch Simon’s reflector :laughing:
Maybe check if you can get a new reflector before cleaning, just in case it gets fubar.
The coating is pure aluminum and is soft as warm butter, so basically untouchable ( exception for Enderman’s method ).
Even can air will damage it, if Freon comes out accidentally as it has already happened to me twice.
Only the small cheap plastic reflectors are chrome coated and are easily cleaned without damage.
I will try the warm sink water, then distilled water, can air method on a spare reflector.
I just screwed up an S3-21700's host reflector, luckily there are spares. But it's very easy to damage the reflector surface with alcohol, super easy. I gave it a bath of isopropyl alcohol, rubbed it with a q-tip, and I was already noticing some subtle white streaks. Then, after another bath in ethyl alcohol, the white streak index increased… :facepalm:
It's hard not to be judgmental with this stuff; with how easy is to screw up standard reflectors, that is. I don't think there's a real need to make something so fragile. :|
Hope I learn the lesson this time. O:)
Nice info. I would love to see all reflectors made with a durable coating.
So no one want to listen to me? Than fine you’ll all destroy your reflectors… Enjoy on a hard way
For the last time LCD TV soapy fluid & superfine microfiber clothes!
Microfiber clothes that is used for riflescope cleaning, and there is nothing more sensitive than AR coating of riflescopes and some are in 2000$ range.
So spray with mentioned soapy fluid, blow that with compressor or compressed air and then gently use superfine microfiber cloth in circular motion.
Done that with cheap plastic reflectors(Jacob A60) and expensive reflectors (olight, Dereelight, Lumapower) and I never damaged anything…
Just because a rifle scope costs $2000, doesn’t mean it’s coating is softer than the aluminum coating on a reflector. It might be, but I doubt it.
Reflectors really shouldn’t get that dirty. Usually they’re inside a light, which should have o-rings preventing dust ingress. The only time dust should get on them is during disassembly when modding.
And for that just take care not to sneeze inside your reflector when the light is open. Use a Kleenix!
The few specs of dust or lint that get inside while modding can just be blown off. Compressed air canisters also work, but keep the nozzle at some distance from the reflector. If you have it too close it may leave a layer of gunk. A safer idea is probably to use a camera squeezebulb or a compressed CO2 canister with no propellant.
I can confirm that cheap microfiber cloth is bad idea, here's my Mateminco MTY1
but I had to disassemble it. because it rattle, and after disassembly if couple times, I got it to stop rattling, but had ton of dust on reflector, and ton other stuff on glass. The design is just bad, you screw aluminium bezel directly to the glass, without an o'ring. And the reflector is held in place by only inner o'ring beneath the glass
With this you mean some sort of cleaning fluid aimed at TV screens, or maybe those cleaning fluids available at optical stores :???: for glasses and lenses. Cleaning fluids which don't mess with the reflector surface, that is.
My reflector was already “stained” with some rosin flux, and so I guess that I probably had sentenced it to death already.
What you did here?! Like you used sandpaper :laughing:
Should I quote myself again from this thread? Ok here we go:
Of course if you use kitchen microfiber clothes that you’ll damage things up. You have super superfine microfiber clothes. Put this into aliexpress search-bar: ” 400*400mm Big Size Cleaning Cloth Chamois Microfiber ”
The key is to use proper steps in cleaning for example if hot rosin flux exploded into reflector during soldering like it happened to Barkutti immediately take mentioned soapy spray solution and spray whole reflector. After that use compressed air or air compressor. Now when things are blow out and dry use superfine microfiber cloths to gently wipe reflector into one way circular motion (not bad idea to hold cloth in one hand gently pressed to reflector surface while spinning reflector with other). Use one side of microfiber cloth while doing that, than other dry side for finishing. You got to have “touch” for everything you do.
For delicate surfaces like reflector one you surely don’t wanna roughly rubbing things out… So you find out that on a hard way…
For some China reflector it is impossible to remove some speckles inside of them cause they are product of bad production process… So if you can’t do it gently you’ll certainly not accomplish anything roughly.
There really isn’t a need to solder when the reflector is exposed and actually inside the light.
When soldering, place the reflector on the other side of the room in a closed box. That way there should be minimal risk of stuff splattering into the reflector.
