Emisar D3AA is available now
Ordered Black XPL hi raised switch ring amber backlight with magnet.
Technically ok, but when to use 2*18650, it will be hard to change the batteries, since you can not remove the screws every time to
change the batteries. Or to use the built-in charger, the light will become more bulky.
Hank can you mix mix sst and osram?
Yes, we can mix the LED, but since those two type of LEDs have different VF, not sure how well they work together.
I just want to mention this is a generally a bad idea. The Vf of a diode is dependent on its temperature, the current supplied to each type of emitter will be different and most likely not going to result in the output or beam you think it will unless the Vf is closely matched. Remember we aren’t running resistors to each LED with this driver.
I am interested in this emiter.
How does it compare to the SST 20 or E21A 2700 K ?
Is it on the green or the rosy side ?
Thanks for the info, I just liked the idea, will it be osram w1 or W2?
I also like the idea of xpl hi 2800k I appreciate you guys and of course you hank
How about adopting some ideas from Nitecore‘s EC4GTS? (pictures borrowed from here).
[quote = Hank Wang] [quote = Tubercle] Требуется версия этого светильника 21700, больше энергии для 8 излучателей. [/ quote] Мы желаем, чтобы свет был как можно меньше и компактнее, в то время как 21700 сделает свет значительно больше, что не является нашим намерением. [/ quote]
The thickness is no more than 2 mm, and the length does not increase at all if you remove the eyelet for the lace and possibly the magnet.
Hank said they didn’t want it bulky.
Two 18650 would make it much more bulky. Sure there are major benefits to 2 cells as well, but I personally prefer Hank’s approach.
This carrier tube looks nice, but it needs to be parallel 2×18650, and not serial 2×18650, like in this picture.
Hi Hank. Could you post a general photo with all possible button colors? I can’t figure out which color of the button should I choose.
I received my D4V2 Ti with XPL-HI T6 8D emitters and made some measurements to compare the max output level to other Hank lights I own. I will post them here, as a point of refference for anyone that is interested. Included, are 2 D4V2 Ti lights with Nichia 219b emitters, which I modded myself. All lights use the standard driver except the E21A lights that use the 5A CC driver.
According to my measurements, Hank's lumen values are quite optimistic. I have calibrated my setup with 3 professionaly measured lights and all Olights that I measure are spot on (Olight is known for giving accurate lumen values). That said, the lights are still very bright, just not as bright as advertised.
Here are my measurements. All values are at startup. The batteries used were a 20A 18650 and a 10A 18350.
D4V2 Ti
XPL-HI V3 3A
D4V2 Ti
XPL-HI T6 8D
D4V2 Ti
219b sw45k
D4V2 Ti
219b sw30
D4V2 Ti
E21A 3500K
KR4 Ti
E21A 2700K
KR4 Ti
E21A 2200K
18650 3693 2365 1634 1455 1041 949 775
18350 2991 1961 1478 1292 1041 949 775
The (very) first impression on the T6 8D emitters is that they are very warm and nice. They are actually warmer than the E21A 2700K but not as warm as the E21A 2200K, so I would guess they should be somewhere in the 2500K area, but I do not have the equipment to measure that. They seem to have a pleasant tint, below BBL, but next to the 219b sw30 they look greener by comparisson, albeit warmer.
Colours rendered under the T6 8D pop quite nicely and the reds are much better than the R9 value of the emitters suggests.
All in all, a very nice emitter. I still prefer the 219b emitters, but a 62.5% increase in brightness while being also about 500K warmer and maintaining a >90CRI is a definite win for me.
I guess a Ti version would not make much sense because of the design of the head. But are you going to make a copper version of the DT8?
I found some pictures on Reddit. Do I understand correctly that cyan and green switch will be the brightest?
At the request of my esteemed friend, jon_slider…
Shot with the white balance set manually to 5500K.
Appreciate you taking measurements but IIRC Olights are also known for having cool tints, and from what i’ve read on here meters don’t always read consistently across tints so it may be that while your setup is good for cool white it may not be accurate for warm white. Is that a possibility?
Hank, does the DT8 have 2 MCPCBS and optics side by side covering 4 LEDs each or is it 1 optic and 1 MCPCB for all 8 LEDs?
I calibrate my measuring equipment with 3 professionally measured lights, at 3 different CCTs, ranging from cool to warm.
It may not be a professional integrating sphere but it is as accurate as it can get, for what it is.
That can’t be someone’s collection, that’s over $1000 bucks.
