Yes, and I want it back
Are you listening, Dennis?
Hello, this white 16340 has been out of production for a long time
At present, vapcell 16340 650mah 6A T6 battery has just been launched, which is also white
If there is a demand, you can consider purchasing
Will do, but can’t find it in your AE shop.
Any reason for that, Dennis? The other cell had higher capacity and current! Was there any suply issue or security?
These are poor capacity and dischcharge current so i wouldn’t call them upgrade.
Why going south when old white was the king?
The old version of white battery was customized and researched by vapcell alone in cooperation with the battery factory, but the sales volume was too small for the battery factory to bear, and the factory had to rely on large sales volume to make money
So it has stopped production
The flashlight Market is too small, and the sales of high power batteries are not optimistic
Vapcell 14500 1000mah 10A also encountered such a low sales situation
Hope the future will be better
Vapcell T8 and T6 can meet the needs of high capacity and high power flashlight users
Welcome to purchase
MascaratumB: vapcell Dennis:Hello, this white 16340 has been out of production for a long time
Hope the future will be betterVapcell T8 and T6 can meet the needs of high capacity and high power flashlight users
Welcome to purchase
Yep, we have to rely on other markets to keep these batteries alive.
Years ago, it was laptop batteries that brought 18650s (low drain) and power tool batteries (high drain). Then Tesla with their massive orders of 18650s from Panasonic (later to be 2170s), and then Vaping with more of the high drain variety of 18650s.
Nowadays we’re basically relying on Tesla, Vaping, and Power tools to get the batteries that we want, so we have to work around that. I’m honestly surprised that we got 26650s.
It looks like the T6 16340 compares quite admirably to the old 800mah white version. The voltage curve is more square, and the capacity difference is mostly made up at low voltages (<3.3V). 6amp curve looks great and is really all that’s needed from this size cell. Hope to see HKJ add it to his comparison tool, but it seems like it might be the best option available. If Illumn gets these I’ll buy a pair before they disappear too.
Welcome to purchase
That’s sad to hear.
So that means we’re not going to see the Vapcell 800mAh 16340 7A (white) anymore in the future.
HKJ reviewed it here:
Vapcell INR16340 800mAh (White) [image] Official specifications: Model: INR16340 800mah 7A Size: 16.4*34.0mm Type: button top Nominal voltage: 3.60V End-of-charge voltage: 4.20V End-of-discharge Voltage: 2.5V Typical Capacity: 800mAh (0.2C discharge) Min capacity: 750mAh (0.2C discharge) Weight: Max:20g Internal resistance: Max:20mOhm AC 1kHz Standard Charge: 500mA,CCCV 100mA cut-off Quick Charge Current:1000mA Max Continuous Discharge Current: 7A [image] …
And the same will be true for the Vapcell H10 1000mAh 14500 battery - we may soon not see it anymore?
Vapcell INR14500 H10 1000mAh (Purple) 2020 [image] Official specifications: Model: INR14500 H10 Size: 14.3*49.4mm Type: Flat top Nominal voltage: 3.60V End-of-charge voltage: 4.20V End-of-discharge Voltage: 2.50V Typical Capacity: 1000mAh (0.2C discharge) Min capacity: 900mAh (0.2C discharge) Weight: Max:24g Internal resistance: Max:18mOhm AC 1kHz Standard Charge: 500mA,CCCV 50mA cut-off Quick Charge Current: 1500mA Max Continuous Discharge Current: 10A Ope…
Are there other (special formulated) Vapcell batteries that will not be produced anymore in the near future?
Eg. is Vapcell T50 still going to be produced? How about the rewrapped Sony VTC5D (Vapcell 2800mAh black) or the Sony VTC6A 18650?
very interested.
Ahh, thanks Dennis! I'll apply for the refund.
Refund granted on the two K64's. It went through the process quick, but required submitting a pic so I just took a pic of the cells with my notes.
Wait, that wasn’t the 16340/850mAH, was it?
Ancient history by now, but I won one (two?) of the 850s back last July in a giveaway‡ but never got ’em.
I still got a bevy of 16340 lights I wanted to load up with decent cells, but never got anywhere with that.
Especially my i332s that could benefit from decent 16340s, ’though the come-with Wuben cells seem pretty good.
So what’s the consensus on decent 16340s… at least those that can be gotten relatively easily?
‡ Had to goggle it, Giveaway!!vapcell battery The event is over,The winners have been announced . No pix, model numbers, etc., for the 850s in question. So I take it those aren’t the white 800s, right?
Yeah thats what I’d like to know also.
I measured my Nitecore NL166 with >4A for a blink on that 15mm MNT FET+1 driver / Osram WF2. It’s my most powerful 16340, but I have only this one and don’t know if there’s a significant variance, also cannot do professional measurements.
Edit:
The 6A Vapcells are now listed on AE. Ordered two .
vapcell Dennis: MascaratumB: vapcell Dennis:Hello, this white 16340 has been out of production for a long time
Welcome to purchase
That’s sad to hear.
Test/review of Vapcell INR16340 800mAh (White)And the same will be true for the Vapcell H10 1000mAh 14500 battery - we may soon not see it anymore?
Test/review of Vapcell INR14500 H10 1000mAh (Purple) 2020Are there other (special formulated) Vapcell batteries that will not be produced anymore in the near future?
Hi
Hi, some batteries are available. If the production capacity is too low, there will be the possibility of out of stock or shutdown
Vtc5d(Vapcell 2800mAh black) is in small stock, unit price is very expensive
18650 vtc6a is expected to be available again, and it is expected to be updated next week
T50 batteries out of stock, hope there will be new arrival
With the continuous progress of lithium battery technology, there will be better batteries facing the market in the future
Hope everyone has confidence in the future
Vapcell will continue to provide customers with high-quality cells in the market
thank you
Edit:
Thanks
d_t_a:So that means we’re not going to see the Vapcell 800mAh 16340 7A (white) anymore in the future.
The Vapcell T8 (purple) is 16340 850mAh (3A rating) = still in production
The Vapcell white is 16340 800mAh (7A rating) = to be discontinued, per my understanding
The Vapcell P1608 is a 16340 800mAh with built-in USB charging port (? A rating)
Ah, great summary, tnx!
Dunno if the Wuben would benefit from a high-drain cell, so might as well just keep the come-with cell.
It is sad if the 14500 1000mah 10A is discontinued. That is such an excellent cell. The biggest issue is that besides the FWAA, there really aren’t any flashlights that can take advantage of this beast of a battery. There needs to be more multi emitter 14500 flashlights for this battery sales to take off.
vapcell Dennis:The flashlight Market is too small, and the sales of high power batteries are not optimistic Vapcell 14500 1000mah 10A also encountered such a low sales situation Hope the future will be better
agreed! I am running the epoch 10amp / 1000mah cell in all 10 or so of my 14500 lights, and they are great! I am pretty sure they must be rewrapped vapcell's. And they are fantastic
