Sofirn is not talking about their source either… someone sells these for about $2 SOMEWHERE (in China)
Richfire looks like the source to me. Contact them. They also have a 21700 tube style LEP with USB-C charging… linking that in the LEP thread… but anyway they look like they blatantly clone some Surefire and Streamlight designs. Heck, you never know, they could even OEM those two. It’s China after all.
Thanks for the lead… I’ll contact them for an OEM opportunity… but it will be a while to get any info as I’m out for a week starting here in a few days (offline and out of the country)
Wurkkos uses the same one. It’s definitely a rip-off of the Streamlight switch. Maybe a reason they don’t want to disclose a source.
I looked again and although the switch itself is identical, the wire isn’t coiled like the Sofirn version. But I’d prefer no coiling actually as it gets in the way of things.
Good find JaredM! I’ll see what they say.
Made some prototype . Led directly connected to switch. Full DD power output for 4min , latter starts to drop and in 30sec goes off at Vin 2.8V, at 3V - moonlight, at 4V - 1A. So its like batt indicator and LVP ;)) To recharge you need to turn off for second or few . It works like 1 mode DD. Main driver is unnecessary ;))
https://www.aliexpress.com/item/1005002531487215.html
Found the switch sold separately. Not cheap, but comes with a mount.
So I got my parts in today. Don’t yet have the PCBs so I ‘air wired’ everything. First run with a 1500mah cell @ 3.7V starting lasted 13 minutes before hitting the LVP flash. Retesting with charged cell but thinking something in the 15min is going to be where it lands. I started with a 4.7Mohm gate resistor and the turn off response is just slow enough to cause mode switching to be effected ( off time needs to be a few hundred ms longer than normal ). I’m going to try doubling them up and seeing how 2.35Mohm behaves.
Important note: the 22mm four mode sst40 Convoy driver that I received a few weeks ago works without any additional modification.
EDIT: 2.35Mohm works perfect. Starting the runtime test, but it should be right around 6-7 min.
Good News! I hope the ramping driver used in the C8+ and L21B also come ready to use. But good to know what will be needed if not. Excellent work JaredM!
So the runtime is going to depend on the output level and when it hits LVP on the driver it seems. Since as the capacitor drains, the Vgs decays. Rds-on then climbs an exponential curve as Vcap approaches G-S threshold voltage. On mode 2 of 4 the setup ran over an hour before I cut it short. On mode 4 of 4 (~6A) it ran about 3.5 min. Mode 3 = ~4min. I feel like there is going to be dependencies on the Vf of the emitter too, so I’ll test something high (was using LH351D).
I get some may want longer run-times, but for use on a gun pig hunting (with my hunters and I the last two years), we never run the gun light more than 30-45 seconds at a time when making the kill shots.
When hunting on the move— the usual run time is a few seconds- every five minutes or so to check the field as we move forward to new areas. So about 10-15 times a night (for 1-2 seconds) if stalking for a few miles in woods. But we mostly sit and wait (with night vision) for most hunts and then we only use the gun light to make the kill(s). They are a LOT cheaper than thermal scopes
In any case, when we see a pig the gun turns on and the first bullet is flying 2-5 seconds later- with several shots also sometimes made after that (going after pig #2 and maybe pig #3 if they don’t bug-out too fast). But the party is usually over in under a minute (coyotes are usually one-and-done (10 seconds).
We use hand-held lights for longer views if we need longer light run times (and we often stalk with red lights in the hand, or moonlight also works great if you have it).
So in my use: if this driver can stay on for about a minute with the C8+ and L21B, that is long enough for me. Any longer is “gravy” time
The C8+ CULPM1.TG light runs at 8A (full output) and IIRC the L21B also does 8A at full power (Funtanstic may correct me, while I’m also not sure it’s the same driver/output as the older/heavier L21A).
JaredM if someone needs to modify the driver in order to make the switch work please show us where we would have to add bleeder resistor on the driver?
Not anyone here will be happy to modd their driver in order to make working FET switch… Especially if it is complicated.
I thought it could act like plug and play switch and work without any modifications on the driver? Lexel battery powered fet switch did not required any modification on the driver.
The power has to come from somewhere, a coin cell in the case of lexel’s solution, or the light cell itself through a ”bleeder” resistor connected between Bat+ spring and Bat- ring. On some drivers this can affect mode selection unfortunately.
If you want something universally compatible with no modifications needed then the coin cell is the better solution, with a high pulldown resistor value it will last a very long time before needing to replace the cell.
“On some drivers this can affect mode selection unfortunately”
I have Lexel battery FET switch and my old type of driver lost no memory effect and went to next mode memory…
But I use different single mode driver so mode changing is a matter of past for me. But anyway it would be nice that this works for people that still use multimode drivers
If soldering bleeder resistor to driver is easy like this it should not be big deal in soldering that resistor.
Couple of pictures explains better than thousands of words…
That picture is a valid example of a bleeder mod. On some drivers that may be the best spot, but others maybe not. The only rule is a resistor goes between Bat+ and gnd. Very simple.
I’m not going to buy every driver in the world and test it with this switch. It’s made for modders, so while I will do my best to guide people and answer questions as I always do, I’m not making any promises. For the members buying these in qty to resell, it is ultimately on them to do the R&D to validate what they make and sell. This is a hobby for me, not a business. I do things for fun and for helping out the community, but I have limitations. I’ve already been pretty generous I feel and offered to test a handful of go-to drivers if someone sends me one. Also, my offer still stands for people to pay shipping on the Beta run of boards to test against their products. If you are interested in that PM me. PCBs should show up this week and I could have them out next day.
1 Mode Real Direct Drive 17mm Blank Driver with bleeding resistor ;))))
Have made PCB panel for cheaper production and convenient use with stencil.
JaredM,
I now understand that bleeder mod on driver… Piece of cake I think that it is not big deal for personal mods or if someone starts with flashlight sale from 0.
But it is big deal and problem if someone who already sold lets say 200 of lights on market and now he wants to offer special version of FET switch because that switch won’t work with that lights because previous versions of lights don’t have bleeder resistor modd on drivers.
My testing would not be relevant to BLF members because I have market unavailable single mode FET drivers made for me by Led4power.
The best test would be on generic type of drivers(Simon, Mountain Electronics, Kaidomain, etc) that most guys use here.
Fake Driver to use with tail cap switch. Real 1 mode Direct Drive.
Looking good… :+1: Maybe you guys could also offer version of switch without bleeder resistor modd on driver? If only solution is battery powered than I am pretty sure there would be great interest for such versions too.
But of course this FET capacitor switch with driver bleeder resistor modd is much better solution for someone who does personal flashlight modd or if he is starting flashlight business from scratch…
So JaredM… wassup’ with the PCB parts?
Some personal life events taking me out of the spirit. I have received the boards and parts, built one by hand, tested it. Performs as I was describing earlier in this thread. Mosfet capacitance being high is keeping the gate resister in the low single digit megaohms, therefore restricting constant on time with multimode builds. The lower the Vf of the LED the better it seems. Overall it does what it’s supposed to do.
I’ll look into bringing this back online later this week.
