Thanks for the quick reply and confirmation regarding the flashing pins!
Although I don’t insert batteries incorrectly in flashlights (at least I recall very very few times where I may have accidentally did that in a flashlight or when it’s really dark), but in the case of the FW3X, will keep in mind to double check that battery is not inserted in reverse…
Please do NOT attempt to put batteries in reversed direction into the FW3X! I have sold my fully functional FW3X to a fellow member on TLF. He made the mistake to insert his battery in the wrong direction. He said the flashlight immediately started to smoke and some chip was burned up.
Thanks for the replies. So it’s the same and only Lume1 driver that’s used on the FW3X (I recall reading that the high-end FW3A Mokume and Damascus also came pre-installed with Lume1 driver, which has to be the same one.
I’m reading the Lume1 description more carefully — it states that Factory Reset was previously not enabled. But in a later comment, it says that Factory Reset is now enabled.
The Anduril version (via 15 clicks) installed on the FW3X blinks out the date 2020-02-24.
I tried doing the 13H for factory reset, and that doesn’t seem to do anything on the FW3X. (which Anduril version/date for Lume1 will have Factory Reset function?)
Also, the description indicates no need to calibrate the temperature, as it should be shipped with the correct ambient temperature, right?
Mine blinked out -- -- - (21°C), so apparently it was correctly calibrated. But.... no matter what threshold I set for the stepdown (45°C or 65°C), my FW3X immediately (i.e. after 3-4s) stepped down from Turbo to a way dimmer level (ceiling?). This is a major downside imho, so I decided to sell it right away.
I have and I think all have the same “problem” with the Lume 1
Is a very good driver but the only way to run turbo constantly is 2H from OFF.
There is no step down to ceiling if i am not wrong
Hey guys Im new here so changing driver and lights in fw3a will be a hard work for me. Is there any chance that we see ready sets of fw3a+lume1 driver for sale somewhere? Maybe nealsgadgets? Maybe there are trusted people who can assemble this flashlight for order in this forum thread?
Hello!.
I’m going crazy with two Lume1 units. In both the battery check and storm mode are very slow. I have checked welds and even cleaned with isopropyl alcohol but without solving it. The other modes work fine. Even the factory reset led blinks slowly. I do not know what to do.
Hello. I have contacted
loneoceans and commented on the steps to follow to solve the problem. Basically the fuses came changed. If you have this controller and the speed of certain parameters fails, you should put HIGH fuse 0xE2 and low 0xDE. This help is thanks to
loneoceans.
Fuses are what you could call settings for the microprocessor. You can set some things like at which speed the firmware program runs at. Some firmware code can be dependent on what these speed settings are set at. The person who wrote the firmware knows what the values should be in order for the firmware to function correctly.
