Thanks jeff, I have seen several ‘knockoff’ models that are about half the price, but I’ve seen mixed reviews. I’m convinced I need a Sailrite.
That reminds me, I bought Phifertex fabric from Sailrite to repair four outdoor sling chairs. You know, the aluminum chairs with the fabric that rots in the sun until an unsuspecting visitor falls through the seat? The Japanese Kenmore model I mentioned earlier did great with multiple layers, using 4 oz V-69 thread. :+1:
The hard part was stretching the new panels onto the aluminum frames. It involved many clamps and some ratchet straps to string the chair between two of my cars. :partying_face: The whole time, my mind was busy imagining the fancy jig they must use at the factory to assemble the chairs. I’m not surprised they all end up on the curb instead of being repaired.
The sewing thing is another serious rabbit hole which I’m trying not to fall down.
For those interested in this stuff, I found The Thread Exchange to be one of the most useful sites as far as learning about Thread, Needles, and that sort of thing.
They list the characteristics of Nylon, Poly, Kevlar, Nomex - Etc. threads.
When shopping for thread in the big box stores, they never list a thread weight. That’s really a pisser.
For heaver duty home use that should work in most machines, I’ve found “Upholstery Weight” in the home sewing sections of Walmart, is “usually”
0.012” thick (as measured by me - but listed as 0.0115 in some specs) which is size 69, Tex 70, or Gov E. It sews fine on my old Singer 66 with a size 16 needle.
The old iron is supposed to handle a bit heavier with a #20 needle, but I’ve never tried it.
Some of the threads marked “Heavy Duty” are thinner than 0.012 but still thicker than typical sewing thread. Size 30, Tex 3, Gov AA, .0080
A size 16 will punch through 6 layers of denim where a thinner size 11 (with thinner thread) wants to deflect.
Some specialty stores sell thread that is water soluble. No idea why, but I can see some serious practical jokes involved.
here is one tip: i wondered once if using monofilament fishing line to sew clothes would be better.
answer NO for many reasons
mainly it will destroy any nearby cotton or polyester thread or fabric
and it does not stretch at all
Years ago I bought some underwear. The damn stuff was sewn with monofilament.
Chewed through the fabric.
It abrasive as hell on skin too. Ended up pitching all of it.
All the Best,
Jeff
Here ya go! It’s a real piece of sh*t. Of coarse anyone who knows anything about sewing is probably just face palming. Every time my girlfriend uses it she wants to go office space on it:
Was using a different hosting provider, which seems to cause problems for some web browsers. I've gone back to my original hosting provider. Everything is working now.
goshdogit,
I took a look at the Sailrite shop. I’ve looked at their machines in the past. Watching the videos, it looks like the Fabricator machines are the only ones they sell that are true 3 motion walking foot machines. That is the needle moves along with the top feed dog.
The lesser machines and the leather machine sure look like the needle is stationary and only the top and bottom dogs move.
Might be wrong, but that’s what it looks like.
Anyway, this might be a consideration to ahhh… consider when looking at the different models.
Their servo seems to be a better unit that anything that comes on the clones or even the “real” machines.
What do you call a clone of a clone?
Nice that they have parts listed and available. That’s a real plus instead of depending on an unknown supply.
I’m holding out for a cylinder bed machine. Just seems like that would be more versatile for what I want to do.
But boy, are they expensive…
I’ve got a Featherweight too. Came to us from my wife’s Aunt. Didn’t know what we had until I looked at what they are selling for. Really nifty for light duty sewing. Surprising too see so many of them here.
After giving the 66 I got last week a lube and workout, I’ve started a more in depth cleanup and lube.
The needle is slightly off center in the bobbin hole. The only adjustment is to loosen the three screws that hold the head to the base of the frame. Then try to tweak it into position.
That’s a little frightening. If I screw that up, well, it won’t be pretty.
I made a shim for the needle holder that gets it lined up - and it works. But my OCD brain half wants it perfect.
You’re correct. They use the terms ‘walking foot’ and ‘compound walking foot’ to specify whether the machine has needle feed.
Sailrite’s page here has excellent demonstrations of the different types of feed mechanisms. I wish I’d seen it before I posted my explanations for zoulas earlier in this thread.
got it like 5 years used prbly twice as many times since
my mother gave it to me when it threw the dog gear, the repair shop told her it was too expensive to fix, not worth it, throw it away, when i was at her home, i took a look, plastic dog gear broke apart, i looked up online, the part was 15 bucks, i always knew how sewing machines work, and were made, but i never actually took one apart before, it took me no more than 2 hours, to fix, clean, adjust, and clean up the mess i made while doing all that
how long would it take an experienced repair guy to do it? prbly half an hour? why wouldn’t they take it, and make money? it was not expensive at all, oh well their loss, now i got the machine, and know how to fix, adjust one,
the same way i learned how to groom dogs, 10-12 years ago the groomer i used stopped doing it, so at first i trimmed my dog a bit, next time a bit more, looked at few YouTube videos, and now, i’ll will never need to take my dog to a groomer
That’s a singer 491. A very serious industrial sewing machine.
Take a peek and see if you can see where it was built.
These things came with a clutch motor and could run at 5000! stitches per minute.
Think sweat shop with 50 of these things screaming out at once. Churning out garments at a fast rate.
It should be able to sew through most any garment - jean weight fabric.
Think a home type machine, all metal, on steroids. It’s not really designed for leather of heavy thread.
If yours is not beat to heck, parts should be readily available. But mostly these were rode hard and put up wet…
Looks to be missing the pressure foot and the dingus that holds the needle. And some stuff that sits on top to control the thread.
For mere mortals, getting a variable speed servo motor makes it controllable at slower speeds. Cost $140-$150 ish for the servo control.
Depending where in Texas you are, there might be a repair shop that could take a look at it for you.
I’m sure you could make or modify a table to mount it.
Get it working and it would be a fun toy that will last home type users forever.
All the Best,
Jeff
