Flashlights’ maintenance is essential to prolong the life of them. How do you care and maintain your flashlights? There are some suggestions, which may help keeping flashlights in good condition.
Cleaning and inspecting the flashlight body
First off, look over the body of the flashlight, especially around the bezel and lens. Check to see if there are any visible signs of any damage. Use a small nylon brush to loosen any dirt or mud that may have become stuck. And for lens’ dust and dirt, use a microfiber cloth dipped into some soapy water and carefully wipe over the lens.
Cleaning the threads
The threads should have a smooth action when unscrewing. If they feel gritty or unsmooth, there may be any dirt or dust has got onto the threads. After you have the flashlight disassembled with the battery removed. It’s time to clean the threads on the body. Remove the O-ring seal if it shows visible signs of damage. Rub some Isopropyl alcohol with using a soft cloth around the threads. The O-ring should be removed easily after you cleaned any dirt and grease. If the O-ring is stuck, use a ring and seal pick tool to loosen. Replace a new O-ring seal if it was damaged.
Lubricating the threads
After cleaning the threads on the body of your flashlight. Then to apply some lubricant to both the threads and O-ring. Use some lubricating oil around the threads sparingly using a cotton swab. And it’s important to use the correct type of oil and suitable lubricant. Generally, petroleum based jelly may deteriorate O-rings over time.
Check for oxidized or dirty contacts
Check both the tail and head of the flashlight for corrosion and dirt. Use a clean cloth to remove any grease or dirt from all the shiny metal contacts. Make sure the body of the flashlight is screwed back the correct way. And check if the switch works fine.
Keep up this simple maintenance activity for your flashlights 1 or 2 times a year, and it will help them stay in good condition. If you have other suggestions, can share freely.
The ones I put grease on threads attracted dust, sand dirt and grit. Flashlights need little maintenance IMO, just clean the contacts & use healthy cells.
I have to change the needle and dissemble and clean the contacts every now and then
On some of my equipment i’ve even had to swap out a vacuum tube or two :laughing:
Lucky. I’ve had to swap out the o-rings on a few of my twisties. I kept the replacements inside the original ziploc baggies and they were just like new.
