the convoy it comes with a 26650 5500 mah from convoy store on aliexpress and comparing the price its actually very similar price so that is not a concern at all. my only concern was the performance lumens and heat in high modes. to me the specs are similar but whats my concern is real world performance.
I did read that the m3-c has stable performance at %40 which is 1500-1600lumens constant till the battery runs out which is about 2.2 hrs. and all of this with manageable easy to hold temperature of 45c (133F)
Quote
“So, further in order it is worth mentioning the heat dissipation. The maximum brightness for such dimensions is very serious and at 100% power flashlight heats up to a VERY high temperature in a couple of minutes. And even after the stepdown (by the way, you can turn off the temperature down temperature in the settings, but I don’t see any sense in it because of the following) it is still hot for a long time. So I highly recommend not to abuse 100% brightness in this model. Really, to keep the flashlight in bare hands is simply impossible. Consider this mode as a normal short-term turbo for a short illumination and use it with caution.
In short, the heat dissipation is good, the flashlight warms up pretty quickly.
In general, I did not see a clear effect of cooling on brightness. I suspect that for 100% you need to use a flashlight on a cold windy winter night, only then you can see some difference in the graph. And so, believe me, you have enough of these 2 minutes in the turbo. For other brightness levels, the flashlight is large enough to absorb the heat generated. As for the use of a flashlight for a long time (if we are talking about the default thermoregulation settings), even in 56% of the mode, the body digs into a frankly hot state. Therefore, I believe that only 29% ois one that can be used constantly. And all that is higher – a variety of turbo, due to the fact that you just can not keep the flashlight in your hands after about 5-7 minutes. However, in percentage terms, this figure is not impressive, but in fact it’s almost 2,000 lumens. So enough for the eyes, frankly.
” End Quote
so going by that review he is saying that even at %56 brightness he is having problems holding the damn thing lol and that he recommends to run it at %29 brightness which equals to 2000 lumens which is higher than the mc-3’s stable %40 mode which is only 1600lumens… so he covered that part of my question, however he did not talk about whether the light beam will maintain the same 2000lms bean strength until battery runs out or will it do that stupid gradual decrease?
I would not overthink it.
The M3C is a well featured good quality simple workhorse light that will not disappoint.
I have used mine several times today, its now my third most used light (behind Xtar Moon RC2 and Olight S2).
If you decide in the future you want more lights (if you are a flashaholic you will) then consider the hotrod to squeeze some extra oomph but with complications.
I just purchased the convoy with 5500mah battery from aliexpress specially when i asked for a coupon from Simon and he sent it %10 off, it was $48.77 delivered with the 5500mah battery. thanks yall
The stable level depends on temperature; it keeps the temperature steady, not the brightness. Due to the way the circuit works, it gets more efficient (less hot) as the battery gets low. So after it stabilizes, the brightness actually goes up the longer the light is on. At least, until it gets so low that it can’t maintain that much output any more… at which point it’ll drop off quickly and then trigger low voltage protection.
Results are a bit different on different lights, but they tend to have similar patterns. I don’t have a SP36 test with recent firmware, but here are some others to show approximately what to expect, depending on the host, the driver, and the LEDs:
When it steps up, it’s not sudden. It’s generally too smooth to even see without a lux meter. If we zoom into one of the graphs, here’s how those “sharp” step-ups look:
The M3 had aggressive step down but the M3-C doesn’t. In winter I don’t notice any stepdown. You can try double clicking for turbo and see no difference. In the summer I see some step down. Double clicking to turbo will show a noticeable increase.
Not sure what step down is being talked about besides the ‘turbo >to> high’ multiple reviews have shown it to work on high mode %40 1500lms and hold that until the battery runs out after 2.2 hrs without it dropping from 1500lms. That is amazing performance from a single cell flash light without getting too hot to hold at max 113F. Name another light that can do that at similar price with the same specs and usb charging and ill buy that one too.
My M3 does a quick drop to 40% at a minute and a half (it’s 29c here) and stays at that level. I looked at dave1010’s review and he says his M3C started dropping at 4 minutes and had a gradual drop to 40% over 16 minutes so if the samples are typical it does look like there is a difference in temperature control/heat management. The M3C seems to maintain a high output longer. Maybe Simon misunderstood me.
ill wait till these 2 arrive till I buy more maybe we’ll see a banger deal at the 11.11 aliexpress sales
as far as a choice for a thrower the ‘Convoy 4X18A SBT90.2’ or if simon does the L6 in SBT90.2 would be a great contender for a usable thrower its just close to $106 usd rn so if we see a deal by than ill go for it.
