Would it be a good idea to look at doing an emitter swap? I have a hot air station and soldering iron and have done a little smd work. Don’t know how easy it would be to cook the led though.
Swapping the LED would certainly open up your possible flashlight choices. You might search around for posts regarding swaps for specific flashlights. Some lights are easy to mod, while others are especially difficult to open without risk of damage to the exterior or even the inner workings.
I’ve done a few dozen LED swaps and haven’t cooked an emitter yet. I’ve heard that excessive heat may decrease an LED’s lifespan rather than ruin it immediately. Since they’re usually rated in tens of thousands of hours, I might never notice.
If you’ve already got SMD and hot air experience you shouldn’t have much difficulty. I use my friend’s hot air station when I can, but when I’m impatient I’ve resorted to butane torches and heat guns.
You’ll also need to consider differences in footprint and voltage of LEDs. You could get around footprint differences by also swapping the MCPCB, but you’ll also need to consider how it affects the fit and/or focus of the reflector.
FW3A is good, but it’s not what the original poster is looking for. He specifically mentioned he:
does not want Anduril. That rules out FW3A.
wants something durable. His previous EDC withstood hundreds of drops and even being run over by a car. FW3As are very thin. Definitely not durable enough.
wants 800 lumens main mode. Assuming he wants a light than can sustain that output, that also rules out the FW3A which can sustain I think maybe half that.
Get an S2+ (or its 21700 equivalent, forgot what it is, S21 or something) and you can pick your own emitter and driver to pretty much do whatever you want.
I got more S2+ hosts than actual complete lights for just that reason.
Andruil would work if i can flash it to default to a set brightness and have a simple ui with the more complex options hidden so to speak. I did however forget to add one more requirement needs to fit the loop on my pants or have a good quick access holster.
and you can set ceiling and floor to the same value, so that is the only level available
you can also set the stepped mode and the ramping mode ceiling and floor independently
so you could have the ‘stepped mode’ set to one level
then when you switched to ramping you could set ceiling and floor apart so it would actually ramp
anything beats #$#$ing flashing lights
i won;t do it
and i flash and program micros for a living!
Starting to think I might should get two lights. I normally carry my S1R Baton as well an my tn12. Maybe get a lumintop fwaa as the high cri with tailstanding and go for brighter and high efficiency with the main light.
Yup, I agree get a S2 or S2+. The selection of emitters, driver’s, and even tint options should be able to make you happy.
Another plus is the simple UI. You can even choose how many modes you want your UI to have.
Also it appears you put your lights through some abuse. The bang for the buck prices Convoy has will make your wallet smile.
The olights I have all have very poor color rendering does the warrior mini 2 have any different leds cant seem to find any specs on cri. Far as the ace beam and convoy how much throw can you get out of the tir optics my only experience with them is my emisar d4 CuTi with its stock optic and that is not quite enough throw for me. Also with the ace beam it seems to only use button tops I have way more 18650s than I can count and none are button top so kind of annoying for me.
Except for the neutral white and high cri :zipper_mouth_face:
Also, the type of beam is not necessarily the same as the TN, because of the reflector vs TIR :zipper_mouth_face:
Apart from this, it seems to be a good option, specially now that the clip can/seems to be reversible
