Yup, I agree get a S2 or S2+. The selection of emitters, driver’s, and even tint options should be able to make you happy.
Another plus is the simple UI. You can even choose how many modes you want your UI to have.
Also it appears you put your lights through some abuse. The bang for the buck prices Convoy has will make your wallet smile.
The olights I have all have very poor color rendering does the warrior mini 2 have any different leds cant seem to find any specs on cri. Far as the ace beam and convoy how much throw can you get out of the tir optics my only experience with them is my emisar d4 CuTi with its stock optic and that is not quite enough throw for me. Also with the ace beam it seems to only use button tops I have way more 18650s than I can count and none are button top so kind of annoying for me.
Except for the neutral white and high cri :zipper_mouth_face:
Also, the type of beam is not necessarily the same as the TN, because of the reflector vs TIR :zipper_mouth_face:
Apart from this, it seems to be a good option, specially now that the clip can/seems to be reversible
Not a specific light reccomendation, but plenty of folks here will help troubleshoot that TN12 issue - if you could get it working again, it would be a good back-up.
If it could be fixed I would love to can’t figure out how to take apart the head if I give the light a hard knock it flickers and runs on dim so might be a broken solder joint. Still will probably upgrade it. I was thinking of doing so before it died.
Sounds like the Acebeam TK18 with Nichia 90+ CRI is pretty close to everything you asked for except it’s an 18650. I recently purchased the Cu T18 and like a LOT about it… Be aware, though, that is an e-switch with no momentary, and a slow double click for turbo (press and hold from off for moonlight). Nice, WIDE hotspot for decent throw on Turbo, while being wide enough for walking a path in the dark without being a flood.
I “think” the aluminum version allows for changing Carclo optics (like the FW3A uses) for playing with the beam pattern. I can’t get the bezel off of my Cu version to change the optic but I’m happy with the beam profile.
I think they are newly discontinued so there might not be many available.
Some notes…
1. The light comes setup in ECO mode, so for the “advanced” flashlight user be sure to change the setting to “Power.”
2. “Power” mode is only available with 10A continuous drain 18650’s. I’m currently using an LG “brown” 3000mah 18650 that allows full “Power” mode functionality. A Nitecore 18650 w/ Micro usb port fit, but since it wasn’t rated at 10A continuous I could only use the “Eco” mode for full functionality with it.
Tried cleaning contacts and making sure the switch retaining ring is tight? I had a Fenix LD20 act a similar way- tightened the brass ring on the inside of the tailcap and it’s been great ever since.
I bypassed the rear tail cap with a wire lead to check the switch still acted the same. Looking at building a convoy s2 I can’t find a single led that is both high cri and bright as I want so looks like I might have to go with the tir optics to get high cri that bright regardless of the host. Does anyone have any experience with the beam difference between the tk18 and the stock optic on a emisar d4?
The thrunite looks a lot like a couple of the newer Sofirns . My opinion is that Sofirn is like Convoy and is really listening to the feedback from this forum .They've also been willing to put High cri emitters in their lights and mod their own drivers and call them BLF versions .
They're definitely cheaper than Thrunites price-wise ...and tough enough not to have complaints chasing them either .
One observation, d4 should have more throw than tn12,you just can’t see it because the glare of wider beam. It’s not usual throwers with high CRI, because at high distance it doesn’t make much difference. Also, for short distance, TIR produce a more comfortable beam. Have you looked at sofirn TF84 and acebeam T36 4000k?
