I did an relative output test depending on washer thickness yesterday, I’m not sure if it’s still on topic for this thread or if I should post another one ?
With LH351D bin F2R2S2 from Convoy, washer thickness of 1.26mm :
0.1A 89.2%
0.5A 89.5%
1A 89.6%
2A 89.5%
3A 89.3%
1.00mm :
0.1A 84.5%
0.5A 84.6%
1A 84.2%
2A 84.4%
3A 82.5%
0.85mm :
0.1A 80.8%
0.5A 81.1%
1A 80.9%
2A 80.5%
3A 79.6%
I feel that around 1mm is a pretty good spot since there are no duv gain going further down, while the output continue to decrease.
I received some more 5000K from Convoy and they are not as good as the ones I got previously, before they were around duv 0.0020~0.0030 at 100mA, now around duv 0.0035~0.0050, It makes me wonder if its the same reel as before or a new one with a different color bin, this is quite disappointing.
I got some 5700K too, but there have been a mistake because they test the same as the 5000K.
Here is another one 2700K from Sofirn to compare with contactcr one, same beaded TIR as before (same distance, so lux can be compared) :
To put his numbers into perspective 0.003 to 0.0035 DUV is about “average” for most LH351D’s we have seen but the higher end of his range gets into the “overly” green territory.
That’s unfortunate. At the beginning of August I ordered some too because the product page specifically stated SPHWHTL3DA0GF4RTS6 Bin F2R2S2, which I thought was the most desired. Unfortunately I have no way to test them other than to visually compare to my Sofirn SP36 5000K. I’ll have to do that eventually… I wonder if/when the old stock ran out and new bin started being sold.
I really appreciate when vendors specify the actual LED bin, but always have to question the age of the information…
Do you see a sales email on their website ? They have a contact form but I can’t find an email, I’d like to join a picture of the label, that’s what I did last time so that the sales rep sees what I’m talking about (i.e. the ”magic” ), can’t do that with the form.
Speaking of Arrow I see that they now offer free shipping to EU for orders above $50 like Mouser and Digikey (actually less since it’s 50€ for those two), a few years ago they offered free shipping with no minimum which was insane, they stopped because that was probably not sustainable, then there was no free shipping at all so I dismissed this vendor. But it’s good that it is again an option, and they do DDP incoterm like Mouser so no custom fees.
As checked with the warehouse team, the available bin codes for below part numbers are as follows:
SPHWHTL3DA0GF4TMQ6 - F2TMQ2 and F2TMR2
SPHWHTL3DA0GF4RTS6 - F2R4T2, F2R3S2 and F2R3T2
SPHWHTL3DA0GF4VMP6 - F2VMP2
SPHWHTL3DA0GF4UMP6 - D2UMQ2, F2UMQ2
That’s what I feared with the large quantity available, they have multiple bins and I doubt they’ll let you choose from one reel with an order of a few pieces.
Edit : There is actually no detail on the chromacity bins except for 5000K (R3, R4, which are bad)
Re edit : ah no, ”M” means 3-step MacAdam, so 3000, 3500 and 4000 are all 3-step.
A few interesting pieces of info here but ultimately not what I hoped.
1) there is a different, lower, voltage bin (D2) in that one LED.
2) various brightness bins in the same CCT
3) “TM” “VM” “UM” not helpful in determining where LED might end up on BBL unless I misunderstand their specs.
So, what is the preferred source / part number for these in ~5000k these days?
I’m definitely not as familiar with the various color/tint codes as others in this thread but maybe these are a good choice for me to purchase a small pile of?
0.1A 89.2%
0.5A 89.5%
1A 89.6%
2A 89.5%
3A 89.3%
1.00mm :
0.1A 84.5%
0.5A 84.6%
1A 84.2%
2A 84.4%
3A 82.5%
0.85mm :
0.1A 80.8%
0.5A 81.1%
1A 80.9%
2A 80.5%
3A 79.6%
Kaidomain 5700K @ 1A w/ Frosted TIR:
According to the picture in the simon’s store, the last one should be V2Q1S2
Updated. His description does not match the picture
Please test Simon’s 4000k.
0.1A Ambient = 1726.1 Lux, CCT = 2701K (Duv 0.0013) Color Rendering Index (Ra) = 95.9 [ R9 = 74.5 ] IES TM-30-15 Rf = 94.10 Rg = 99.50
0.5A Ambient = 6778.6 Lux, CCT = 2714K (Duv 0.0010) Color Rendering Index (Ra) = 95.5 [ R9 = 73.0 ] IES TM-30-15 Rf = 94.00 Rg = 99.99
1A Ambient = 12251.9 Lux, CCT = 2722K (Duv 0.0007) Color Rendering Index (Ra) = 95.1 [ R9 = 71.5 ] IES TM-30-15 Rf = 93.61 Rg = 100.34
2A Ambient = 21058.3 Lux, CCT = 2720K (Duv -0.0003) Color Rendering Index (Ra) = 94.5 [ R9 = 68.4 ] IES TM-30-15 Rf = 92.71 Rg = 100.80
Sliced 1mm :
0.1A Ambient = 2298.4 Lux, CCT = 2435K (Duv -0.0013) Color Rendering Index (Ra) = 96.0 [ R9 = 74.0 ] IES TM-30-15 Rf = 93.27 Rg = 101.86
0.5A Ambient = 9113.0 Lux, CCT = 2448K (Duv -0.0016) Color Rendering Index (Ra) = 95.5 [ R9 = 72.0 ] IES TM-30-15 Rf = 92.54 Rg = 102.25
1A Ambient = 16433.9 Lux, CCT = 2459K (Duv -0.0019) Color Rendering Index (Ra) = 95.1 [ R9 = 70.2 ] IES TM-30-15 Rf = 91.87 Rg = 102.53
2A Ambient = 28013.9 Lux, CCT = 2464K (Duv -0.0027) Color Rendering Index (Ra) = 94.3 [ R9 = 66.6 ] IES TM-30-15 Rf = 90.77 Rg = 102.79
Recent Reviews: Best Flashlights for Light Painting Photography 2022 // Battery and Charger Buying Guide 2022 // Olight Array 2S Headlamp // Acebeam E70-AL CRI95+ // XTAR VC4SL Charger // Sofirn D25LR Headlamp // Convoy T4,S21D,M3-C // Sofirn IF22A // Ants on a melon RGB Critter
Affiliate links: Olight AU // Olight USA // Acebeam
Instagram: @stephenk_lightart
Attempting to build a Convoy of Convoys.
I ordered the 1st ones early August, the seconds early September.
Since Sofirn sourced 2700K were nice I bough some more to put in some light bulbs, I also took one 5000K and 4000K to see how they test :
4000K :
0.1A Ambient = 1829.6 Lux, CCT = 3905K (Duv 0.0044) Color Rendering Index (Ra) = 92.9 [ R9 = 72.9 ] IES TM-30-15 Rf = 91.51 Rg = 99.27
0.5A Ambient = 7292.8 Lux, CCT = 3928K (Duv 0.0037) Color Rendering Index (Ra) = 92.4 [ R9 = 71.5 ] IES TM-30-15 Rf = 91.43 Rg = 99.85
1A Ambient = 13191.3 Lux, CCT = 3943K (Duv 0.0030) Color Rendering Index (Ra) = 92.1 [ R9 = 70.7 ] IES TM-30-15 Rf = 91.18 Rg = 100.29
2A Ambient = 22691.5 Lux, CCT = 3956K (Duv 0.0013) Color Rendering Index (Ra) = 92.2 [ R9 = 70.1 ] IES TM-30-15 Rf = 90.81 Rg = 100.58
5000K :
0.1 Ambient = 2210.7 Lux, CCT = 4730K (Duv 0.0030) Color Rendering Index (Ra) = 92.7 [ R9 = 58.1 ] IES TM-30-15 Rf = 89.52 Rg = 97.55
0.5 Ambient = 8847.3 Lux, CCT = 4817K (Duv 0.0038) Color Rendering Index (Ra) = 91.8 [ R9 = 54.3 ] IES TM-30-15 Rf = 89.75 Rg = 97.91
1 Ambient = 16101.2 Lux, CCT = 4870K (Duv 0.0039) Color Rendering Index (Ra) = 91.3 [ R9 = 51.7 ] IES TM-30-15 Rf = 89.70 Rg = 98.05
2 Ambient = 28038.4 Lux, CCT = 4949K (Duv 0.0037) Color Rendering Index (Ra) = 90.7 [ R9 = 48.7 ] IES TM-30-15 Rf = 89.47 Rg = 98.33
thefreeman, work your magic and see if Arrow will reveal what their 4 in stock 90 CRI bins are: arrow results
I’ve never seen anyone able to get this info so you must have the magic touch.
Edit : Nevermind, I found it.
assuming you found websales@ good luck!
That’s the one, we’ll see if I get a reply.
Edit :
There is actually no detail on the chromacity bins except for5000K (R3, R4, which are bad)Re edit : ah no, ”M” means 3-step MacAdam, so 3000, 3500 and 4000 are all 3-step.
https://www.digikey.com/en/products/detail/samsung-semiconductor-inc/SPH...
your link is for 4000k
here is 5000k
if you want to make the tint less green, you can slice the dome off, which also makes the LED about 500k warmer.
High CRI lights for sale
Anyone know what bin Wurkkos has? It’s quite good for 5000K.
Anyone measured spectrum of 3500k from Convoy?
I PM`D Simon at Convoy, and this is the current LH351D 5000k bin SPHWHTL3DA0GF4RTR6 F2R1T2. Does anyone know what the bbl or duv is of this bin?
Looking to buy used Reylight Pineapple? PM Me
In the datasheet page 10 , R1 should be similar to R2 but slightly higher CCT.
Edit : it’s one subrank flux bin higher (T2 vs S2), that can mean a worse tint sometimes (green being more efficient).
I got some but I still haven’t tested them
Dang I bought 4 of them, before I asked Simon for current bin.
Do you happen to know Simon’s current bin for lh351d 4000k?
No idea.
Here is one, bought June 4 2021, with the same beaded lens as my other measurements :
0.1A
CCT = 3319K (Duv 0.0046)
Color Rendering Index (Ra) = 94.2 [ R9 = 77.5 ]
R1 = 94.6 R2 = 94.1 R3 = 92.7 R4 = 96.4 R5 = 93.6 R6 = 92.1 R7 = 97.5 R8 = 92.3 R9 = 77.5 R10 = 85.7 R11 = 96.7 R12 = 78.8 R13 = 94.0 R14 = 95.6
IES TM-30-15 Rf = 93.65 Rg = 99.95 CCT
0.5A
CCT = 3331K (Duv 0.0040)
Color Rendering Index (Ra) = 93.5 [ R9 = 75.8 ]
R1 = 94.2 R2 = 93.6 R3 = 92.2 R4 = 95.5 R5 = 93.2 R6 = 91.5 R7 = 96.3 R8 = 91.6 R9 = 75.8 R10 = 84.6 R11 = 96.1 R12 = 80.1 R13 = 93.6 R14 = 95.3 IES TM-30-15 Rf = 93.09 Rg = 100.75
1A
CCT = 3334K (Duv 0.0032)
Color Rendering Index (Ra) = 93.2 [ R9 = 74.7 ]
R1 = 94.0 R2 = 93.5 R3 = 92.0 R4 = 94.9 R5 = 93.2 R6 = 91.5 R7 = 95.6 R8 = 90.9 R9 = 74.7 R10 = 84.4 R11 = 95.7 R12 = 80.9 R13 = 93.5 R14 = 95.2
IES TM-30-15 Rf = 92.41 Rg = 101.24
2A
CCT = 3326K (Duv 0.0015)
Color Rendering Index (Ra) = 93.2 [ R9 = 72.4 ]
R1 = 94.1 R2 = 94.1 R3 = 92.9 R4 = 94.6 R5 = 93.3 R6 = 92.1 R7 = 95.3 R8 = 89.6 R9 = 72.4 R10 = 85.5 R11 = 95.1 R12 = 81.8 R13 = 93.7 R14 = 95.7
IES TM-30-15 Rf = 91.94 Rg = 101.39
Here for comparison with one of the 3500K Contactcr gifted me (Digikey).
Sliced at 1mm :
CCT = 3014K (Duv 0.0009)
Color Rendering Index (Ra) = 95.4 [ R9 = 81.1 ]
R1 = 96.6 R2 = 96.1 R3 = 93.7 R4 = 96.4 R5 = 95.8 R6 = 94.8 R7 = 96.6 R8 = 92.8 R9 = 81.1 R10 = 89.7 R11 = 96.8 R12 = 84.4 R13 = 96.3 R14 = 95.9
IES TM-30-15 Rf = 93.30 Rg = 101.82
CCT = 3037K (Duv 0.0003)
Color Rendering Index (Ra) = 94.6 [ R9 = 79.4 ]
R1 = 96.1 R2 = 95.5 R3 = 93.2 R4 = 95.3 R5 = 95.3 R6 = 94.1 R7 = 95.6 R8 = 91.9 R9 = 79.4 R10 = 88.6 R11 = 96.1 R12 = 85.1 R13 = 95.8 R14 = 95.6
IES TM-30-15 Rf = 92.17 Rg = 102.54
CCT = 3052K (Duv -0.0003)
Color Rendering Index (Ra) = 94.2 [ R9 = 77.7 ]
R1 = 95.8 R2 = 95.3 R3 = 93.1 R4 = 94.7 R5 = 95.0 R6 = 93.9 R7 = 94.9 R8 = 91.0 R9 = 77.7 R10 = 88.1 R11 = 95.5 R12 = 85.6 R13 = 95.5 R14 = 95.6
IES TM-30-15 Rf = 91.32 Rg = 103.02
CCT = 3062K (Duv -0.0014)
Color Rendering Index (Ra) = 93.8 [ R9 = 74.8 ]
R1 = 95.3 R2 = 95.4 R3 = 93.6 R4 = 94.2 R5 = 94.6 R6 = 93.9 R7 = 94.3 R8 = 89.5 R9 = 74.8 R10 = 88.2 R11 = 95.0 R12 = 85.9 R13 = 95.2 R14 = 95.9
IES TM-30-15 Rf = 90.65 Rg = 103.11
Thank you,stock seem not so good.
Do you like tint when sliced?
I prefer the one from contactcr that is always below the BBL, but it looks okay.
Does dedome lh351d decrease even more the CCT and also blue peak than slicing?
Would be interest on stock 2700k
