Ich wünschte ich wüsste was los ist!!!..aber leider ist mein Deutsch so gut wie mein Swahili
Swapping L21A’s Sst40 with Sft40, sanded down the top of the emitter gasket, and modding the driver to 8A.
Sorry the album was privat,
now it works ?https://www.taschenlampen-forum.de/media/img_20210619-2-rippen-jpg.34344/full
Yep.
Now that’s a head. How many cd?
We hope over 54 MCD
to get on the top.
Regards Xandre
Holy crap!
That flashlight head is huge.
is it high cri?
I could not agree more. They will get dropped and that thin aluminum is not very strong. My EDC FW3’s and FW1’s all have them.
[presumably from thinwall Al tubing of the S11C?]
“Doc, it hurts when I do this…”
“So don’t do that.”
There’s always a price to pay. You want lightweight, you gotta have less metal. You want sturdy, you need more metal.
I got a Xeno E03 which takes 14500/AA, but is almost the size/weight of a compact 18650 light. The walls are so thick, it even has “finger-grooves” milled into the side for better grip. That’s thick. And it’s heavy.
With the S11C, you slip that into your pocket and it almost disappears because it’s so light. Some people value that vs being able to baton a killin’ knife into a log with your flashlight without damage.
It just depends on what you want.
Lightbringer, I mostly agree. But, weight is not the issue. I like the little bit of sturdy protection on the front end of the light to protect my investment, after all they always hit the ground nose first. The FWAA is borderline underpowered for an EDC, but some days in some pants if fits well. Otherwise I am normally going to carry an 18650 light.
Maybe it’s just me, but the only time I ever dropped a light was when I had my MH20 precariously balanced on my bike’s seat when poking around in the dark.
I try to not drop my lights, like, ever.
Some are tools, some are shelf queens and some are in between. I don’t try to, but it does happen. I work around gensets, mechanical vaults and data centers… crap happens.
Maybe it’s just me, but the only time I ever dropped a light was when I had my MH20 precariously balanced on my bike’s seat when poking around in the dark. I try to not drop my lights, like, ever. :laughing:
That may be true, but sometimes your cat(s) help sweep them off the table onto the floor.
Actually it was on a sort of pile of papers and mail that I didn’t get to yet, and that was off a coffee-table, so total drop was a paltry 8” or so.
Work-lights, absolutely, you need rugged. That’s why you’d pick Snap-On vs JiffyTool.
But for the average schmo who wants a light light (ha!), the S11C would be great.
Sofirn IF25 clip mod inspired by M2R clip mod (S2+ clip also fits D4. )
The mod takes basically the same method as M2R mod with a rotary tool / grinder to make the bezel slimmer fit.
Sofirn SP35/IF25 clip, Convoy S2+ Clip, Emisar D4 clip
Modded IF25 clip (2.80mm) vs Unmodified IF25 Clip (5mm)
Perfect on S2+ and D4v2, (The M2R is deeper than IF25 clip but it’s few extra dollars more)
So my curse may have been broken. As of late some of my mod endeavours have failed, but alas I have vanquished by perseverance.
Some time ago I purchased an Amutorch YooToo SD3 that I wanted to upgrade with an SST 70. My first attempt was partially successful but the reflector shorted the leads to the MCPCB. Tried to salvage the driver but ended up with a mess of components that had partially unsoldered and slid around. The second driver was a dud right from the start. Never worked but as I may have done something to it, took the fall and re-ordered a 3rd. Yesterday this one landed in my mailbox and it tested OK.
Then onto some mechanical changes as the cavity of the SD03 is rather shallow so I made an extension ring with a seat adapter of 24 to 22 mm. (on the left the LHT ‘dud’)
Had to replace the solid brass button with a spring. Simon’s driver is more compact (using both sides of the board) and the overall battery cavity is only some 71 mm. After all was done, the driver no longer stayed ON but would flicker and turn OFF. Thinking some brass dust may have gotten caught under a component (I had to use a grinding disc with a rotary tool to cut the button, unknowingly this was just surface mounted).
After multiple cleanings and some detailed inspection, I nicked a few components and traces.
But the driver is still in working condition so I set out to troubleshoot the culprit. It turns out the adapter that I made was not making proper contact along the outside ring of the driver. A bit of solder did the trick. Convoy’s are cleaned with a bevel whilst LHT’s are snapped off the array leaving a sharp edge.
Tonight I’m taking it out for a few beam shots and comparisons to its siblings, the SD1 w/ SST 20 and the SD2 w/ SST 40.
Preliminary tests give me some 2700 lumens. My lightbox will have to be rectified as throwers give lower values than blasters. I believe the concentrated beam is partially absorbed by the styrofoam (it glows throughout!) and maybe a couple of coats of neutral white paint could solve the discrepancy. I also set aside a larger aluminized bubble-wrapped cardboard box, the type used for food deliveries. That may be the better solution.
Devil’s advocate here regarding the S11C thin-wall/bezel-less comments (posts #10067-10073): my EDC (although I don’t use as much with this pandemic and lock-downs) has some wear signs and has been dropped at times but never had any problems with the face being damaged. The lightweight may be the reason, but then again the construction of a plastic retainer and the TIR PolyAcrylic lens does make for a better shock absorber.
Just my nickels’ worth…
Congratulations on the mod, looks a very nice flashlight. My SD3 was lost in the mail more than a year ago, I still like it though.
About the lightbox,the percentage of light absorbed or transmitted by the styrofoam is unlikely to be different wether the light intensity is high or low, so, at least the hardware, should respond in a lineair way to light intensity. The luxmeter could be a source of non-lineairity too, but the few that I measured for that (both cheap and expensive luxmeters) were nicely lineair too.
Thanks for the encouragement djozz.
Had a setback: took it out for some tests against the church and the light flickered then died. Today did a better analysis and the spring must generate much resistance as it partially melted the solder and slid against a very close trace. Can’t find my BeCu straight springs - have to order more I suppose. Then I had some other problems regarding the cleaning solution that I use. It’s too caustic and leaves some residue that does conduct electrically. But for now, it’s working - tough components with all this soldering/cleaning!
As for the lightbox, my theory of the concentrated hotspot; the light is further “pushed” into the material. I know light (photons/or wave) exert no force but there seems more glowing with the throwers than the flooders. And also, the box may be too small at 25 x 17 x 18 (deep) (cm). The meter is an economical UT 383 BT (Uni-T). I’m planning to use the larger aluminized box (future project).
I also just changed the Yinding CULPM.TG1 to a Convoy and the lumen output is the same*. The Yindings would go blue at 8 amps and had to limit the current (6 1/2 A IIRC) with a higher impedance 26650 cell. I tested the Convoy up to 8 1/4 Amps (fan cooled). So I may have a problem with the electrical path that adds some resistance (switch / contact point with the driver’s edge / something else - I don’t know).
*edit: about 1000 lumens.
I made a handle for my GT90.
(Achtung: some sloppy work ahead)
The WT90 is a great new flashlight, but being a 3x21700 light, it is a rather big chunk to hold. It could do with a handle but it does not have one, and no tripod mount hole either.
So I made a plan for making a working handle, with the added plan to learn how to DIY aluminium anodising, I have wanted that for years.
I started with finding out where on the WT90 is meat enough to make attachment holes. TA helped me with a secret technical drawing that shows wall thickness and I must say that the WT90 is leanly built, little unneeded excess material which is good. But not good for my holes! I finally settled for holes around the switch. That flat bit makes for a great attachment point for the handle, good looking too, but a handle there comes at the expense of a little less convenience operating the switch (the switch will never accidentally engage in your bag though).
I decided for M4 threading, so the drill was 3.3mm. Taking the wall thickness into account, the 2 holes at the rear side of the switch were made 9.5mm deep, the 2 holes at the front side of the switch 6.5mm. The front side holes could not be positioned any further to the front because the wall thickness is decreasing fast there. I first marked the position of the holes with a pencil, then made pits with a center-punch, then drilled the holes. It was all by eye so the hole positions were not perfect.
Then the M4 threads were added with a hand tap.
The handle was made out of 4mm x 30mm aluminium strip. Ideally I would have liked 4mm x 20mm, but I needed the width to attach it around the switch. Now that it is finished it feels great in the hand though
First, the attachment holes were made, trying to match the not so perfect positions of the holes in the flashlight. One hole was off so I had to ream it to get the screw fit.
The cutout for the switch was a 14mm hole, with the underside bevelled to completely clear the switch. This was an ugly hole, I should have clamped the strip tight to the drill press when drilling it
Then the handle was bend and then cut off, using a vice and a piece of stiff leather to prevent scratching the aluminium. Also here sloppy work: it is ok but I’m not over the moon with the shape.
Then filing and sanding until everything was very smooth. I planned on anodising, and an anodised finish shows everything, it does not cover the blemishes.
The next episode was anodising. I’m lucky to work as a class assistent/technician in a school, so I can use the fume hood, and I stole some 4M sulfuric acid for this from school (it is cheap so no big deal, and in return, the school gets a new experiment to show in the fith grade, anodising aluminium fits nicely in the 5th grade when the subject is oxidation )
The first step is cleaning the object well with water and soap, then an etching step with concentrated caustic soda. I made some crude video’s of the several steps.
Here is the handle after the etching, you can see that it does smooth the surface a bit and makes for a satin finish, which is nice.
Then after a quick rinse in de-ionised water, the anodising starts in 4M sulfuric acid. I used a large lead electrode for the minus connection, and I clamped the handle in a aluminium hook which is the plus-connection. I tried 45 minutes at 2A. (there are guidelines for which current to choose, depending on surface area of the workpiece, but it is not critical)
After this building-up of the oxide layer, the piece was soaked into the die. This appeared more critical than I thought. I tried Dylon black clothing die first because I found they use that all over the internet. Here is the video, you can see that it does not stick.
After dying, you have to seal the pores in the oxide layer (and thus lock up the die) by boiling the piece in distilled water for half an hour. Well, when doing that, the die immediately washed off so I got a blank anodised handle, really nice but not what I wanted.
So then I went for the real deal, I ordered official anodising die from a german webshop, 16 euro for 10 grams, of which I used 5. The die solution can be used multiple times so I’m good for ever with this. First I removed the old ano layer in the caustic soda step, a bit longer than neccessary to be sure everything was gone, then did the same steps again, but now with the new die (and I went for 3A this time in the sulfuric acid step). Now the handle picked up the die really well, and it did not wash off in the boiling phase. In fact I ended up with a really well black anodised thing :party:
It immediately looked good on the WT90.
The only thing left was ordering some black screws to go with it. I found a nice assortment of black bolds on Amazon, and that indeed finishes the light off
If I knew beforehand that the anodising would go so well, I would have done a better job on the construction of the handle. Still the handle looks fine and it does a great job in handling the WT90 much better than before. Perhap a tripod mount hole in the next WT90 version?, or a proper handle coming with the stock light?
