Hey! Thanks! If I remember my electrical basics... Having 8 channels delivers more current with less resistance; if that had to be done in serial, there would be more resistance, correct? Now I'm going to have to go look, LOL.
Yeah, the Zebralight checks most of the boxes, but is outside my $$$ limit at $119. Even could I avoid the fight with the wife, I don't want to pay that much for a light I may misplace because it is small. Thanks, though.
My S2+ in 7135*8 configuration with XP-L HI emitter can get a bit toasty after a while of running on full brightness, but it’s manageable. Alas, as others already pointed out, it will not maintain 1000 lm output for an hour.
Also, the ones with biscotti UI are more configurable.
Zebralight for sure. Worth the extra money. I have several and at least on of them gets carried every day. Without fail they always work and they take a beating very well.
The SC52w is usually in my pocket but that one won’t meet your requirements. Looks like the 700 would work for you. If you can give up a bit of that run time the 600 series is smaller and rides in a pocket a lot easier as well.
Forgot I had an Amazon gift card! I just spent it on the Unicorn. :-)
I'm likely going to save up for the Zebralight, since it checks most if not all of my boxes. But the unicorn looks fun, so I'll enjoy one of those in the mean time.
The good news is that I got my light today, way earlier than I expected!!! The bad news is that "batteries are not included" LOL. Do y'all have suggestions for good batteries? I'm making a trip on Sunday, so I'll want to either get the battery before Sunday, or I'll have to have it delivered to the in-laws...
Secondly, I realized I hadn't searched before I opened my big reply box... On this forum, it is suggested that the "Samsung INR18650-36G" is also a really good option... But I can find neither of them on Amazon, for example. Any places you can suggest I should buy them? I'm still searching, by the way.
I think Amazon or a local vape shop is your best bet since you need it so quickly. Keeppower has some 18650 protected cells that are high capacity and decent cells, just a standard drain type, though, so not for higher power lights. They're a little more expensive because of the rewrapping and protection, but those might be on Amazon. Amazon is kind of scared of lithium-ion cells, it seems.
Also, there's a shop in California called Aloft Hobbies that several of us bought some large 26800 cells from recently. I was astounded with how quickly they shipped/I received the packages. Neither of my packages were labeled with the "contains lithium battery" sticker like they're supposed to be, so I'm sure that's why they rocketed through the postal system so fast. Anyway, they have some Sony VT6C cells at a good/normal price. They're high drain cells but have a respectable 3000mAh capacity...good choice really. I think they were $6.99 or $6.49 each (some places have upped their price on those to $9 or more, which is crazy) and the shipping was pretty cheap. Might be an option if you can ship to your inlaws.
Many cells from many vendors are out of stock at the moment, except for lower quality ones at some places. Those will still do if need be, just kind of a waste of money compared to a good quality cell. If there's a Sofirn light on Amazon that you like, many of those come with decent cells, too, and maybe you could get those delivered fast.
Amazon had a ton of counterfeit 18650 cells in recent past since there are so many small vendors selling them and source is unknown. Amazon just couldn’t control it, so they ended up removing most of those 18650 product listings. Whatever is left there looks like garbage to me.
Thank you for the suggestions!!! If I may, what is the difference between the button top and flat top batteries, other than the obvious? The Unicorn seems to need a button top is why I ask, and I keep finding flat tops...
I'm still researching, but I figured it was worth the ask.
Button tops are the same cells as flat tops (factories only make the flat tops) but someone has welded on an additional button cap. No difference usually other than a little added length and I suppose there are some applications made to nestle the button in a depression. These days it seems like most of the button tops are also protected cells but from the usual battery suppliers you can get normal button tops if you like. With many chargers, flat tops seem to make better contact (more of an issue with smaller cells but it just depends on the charger contacts).
