If I was hinted at this mod about a year ago, I would have undertaken it. I had ordered a Sofirn C8F with the 3 LH351D emitters ā but was lost in the shipping. After a much longer wait, Sofirn agreed to send another. However, they had no more in stock and I had to wait some more for the manufacturing schedule. All in all, 158 days (~5 months).
Aftermath: But in the following days of that 2nd order, so mysteriously showed up the 1st order. So now have 2 lights.
My stock lights donāt heat up much on high ā 1800lm. On turbo (3600lm) itās a different story. If yourās doesnāt heat up at these levels, I would suspect the shelf extension may not be transferring thermally to the head sides. Does it have much contact with the bowl? Nevertheless, the Sams are tough emitters and are a great choice. All milky white and just the right balance between throw and flood.
I use them on my bike. Best combo of throw with spill. Mostly on High with some moments on Turbo, and after some 2 to 2Ā½ hours, change to my second unit.
The Samās are good tough Leds. I had modded it to a small 14500 host and ran it at max. The heat got the expansion to pop out my friction fit / plastic lens and some damage to the reflector. But it always kept going.
Hey, that would be some machining skill to have a matching parabola cone.
Well, I have to admit thatās way above my skills. My problem is that I have basic skills in many areas, but Iām master of none. Metalworking, electronics etc.
Nice mod Haukkeli! Iāve often thought about modding my already modified C8 into a triple or quad, but itās the spacer that I canāt make let alone custom reflectors. Very creative and looks very cool!
Itās been done before, but I wanted one for myself. FW3A raw converted to an FW1A, by drilling a couple holes, reflowing an sw40 219B, no-FET firmware. SS FW1A bezel. Turned out great, throwy, perfect tint and UIāone of my favorite lights.
Yes, I was able to identify one in a FB for-sale post and snag it. I have a new one, tooāsome day I will do a comparison and post it, although with 219Bs they wonāt match any stock FW1A emitters.
LEDIL Leila optics are a close fit too if TIR is your thing. I am running this one now in my converted FW1A with SS bezel. 21kcd with SST20 4000K off an MJ1 cell. FET is still enabled btw, firmware stock and light is from initial GB.
In the future, I hope to build a LumeX1 and pair it with a Nichia B35AM under a pebbled narrow spot optic in an FW.
edit: Forgot to mention, if you are willing to space up the mcpcb, Convoy S21A/B reflectors fit perfectly in diameter. That was what I was running before the TIRs.
Today I modded my just received FWAA by removing the driver side spring and replacing it with a disc contact. This allows me to run my Shockli button tops that wouldnāt work with the spring in place. Shocked how small the light is honestly. Beam is nice for indoor use, donāt know how much Iāll carry this light honestly, but weāll see. Considering swapping emitters to 219b or a tint mix of SST20s or even giving the HL2X 90CRI emitters a try that are collecting dustā¦
Also in the package was a FW21 X1L. Iām surprised how much I like the host. Looks and feels great in person. Even the ano color is somewhat pleasing on this body (not so on the FWAA - itās about to get stripped or baked). The optic generates a super clean beam that I really like, but throw is disappointingā¦ only 115kcd. Not going to cut it for me. If I canāt get that up to near specād range, swaps will happen. My Convoy M2 does 102kcd and is more pocketable
But really. The UI on this thing is AWFUL! Like wtf year is it? Long press for off, single to advance poorly spaced modesā¦ no, no and no. This will have to change. Already taking measurements to convert this into an ANGIE quad. Hoping to get a driver designed for this running Anduril.
In my case I didnāt space it up, I machined my own bezel thatās a few mm shorter than the factory FW1A. I also had to machine the lower part (last āfinā) of the reflector off to fit within the head cavity.
Taking a second mcpcb, torching it until the top layers separate (doesnāt always work), then filing and sanding it smooth is an option to create your own spacer. Or buying copper discs from Bopper on Etsy is another (easier) option.
Yes. Itās a totally different driver and mcu. No markings and itās small with ten pins IIRC, donāt quote me though. Iāll be tearing it down againā¦ I did swap a Convoy Boost HX in. Throw dropped to 85kcd. Might try a 3000k SST20 next to see how it compares to my LEDIL IRIS in my ET G25C2.
Driver OD is 25.4mm. Cavity is 20.4 mm, so it mandates a 2.5mm ground ring. I wish it used the same driver as the X9L, I missed this detail and am kinda annoyed about it.
