lightsauce
(lightsauce)
November 25, 2020, 5:07pm
319
You’re right, they’re hex not torx.
After a bit of trial and error I finally managed to get all 8 to discharge. Turned out I really had to massage each battery in place, screw in the tailcap, massage then screw in again and rinse and repeat till I absolutely can’t screw it in more. All the buttons are in place and all 8 batteries work.
Still I’m considering taking out the sleeves. Holding the batteries in place is the easy bit, lining them up properly takes a bit of effort and there’s no indication whether or not they’re all seated properly. Thanks again!
Texas_Ace
(Texas_Ace)
November 25, 2020, 5:08pm
320
lightsauce:
Yeah, you pretty much have to bottom out the carrier for VTC6 cells, removing the sleeves should make it easier.
djozz
(djozz)
November 25, 2020, 7:05pm
321
And you could try leaving out that floating PCB between the batteries, you remove some battery reverse safety but for me that solved all contact issues. And I found it easy enough to load the carrier into the battery tube without it.
GT94 Smooth Reflector Availability?
What is the latest regarding the replacement reflectors? I've sent emails to Nealsgadgets and Lumintop requesting my replacement reflector and have not received any replies.
Thanks in advance!
Hardusvd70
(Hardusvd70)
January 20, 2021, 4:15am
323
liteupmynite:
What is the latest regarding the replacement reflectors? I’ve sent emails to Nealsgadgets and Lumintop requesting my replacement reflector and have not received any replies.
Thanks in advance!
I got my SMO reflector from Neal more than a month back.
ImagioX1
(ImagioX1)
January 20, 2021, 4:36am
324
I have not gotten my smooth reflector yet. Have not emailed them about it either though. Were we supposed to email them?
Thanks for letting me know. I sent Neal another email. I hope to hear from him.
Here's the reply I received back in Oct 2020 from Neal. No replies since.
"Sorry
Lumintop make a mistake
I will send a smooth reflector to you when it is available "
Hardusvd70
(Hardusvd70)
January 20, 2021, 7:08am
326
liteupmynite:
Here’s the reply I received back in Oct 2020 from Neal. No replies since.
“Sorry Lumintop make a mistake I will send a smooth reflector to you when it is available ”
Send him a message via messenger.
Theodore41
(Theodore41)
March 26, 2021, 12:59pm
327
Can you please suggest which batteries are best for this light?
Texas_Ace
(Texas_Ace)
March 26, 2021, 1:13pm
328
High drain button top (or solder blobed) cells, 30q works fine. VTC6 works better.
Theodore41
(Theodore41)
March 26, 2021, 1:23pm
329
Thank you very much Texas_Ace.
RamBull
(RamBull)
July 6, 2021, 8:30pm
330
What batteries do you guys recommend using in the GT94?
I tried using the Molicel 18650 P26A with no success.
Texas_Ace
(Texas_Ace)
July 6, 2021, 8:35pm
331
Are they button top cells? You need button top cells or you need to add a solder blob to the top of the cells.
Any high drain button top cell capable of handling 15A should work.
RamBull
(RamBull)
July 6, 2021, 8:50pm
332
Thank you, Texas_Ace. All my 18650 are flat tops.
Any particular in stock battery you recommend?
Texas_Ace
(Texas_Ace)
July 6, 2021, 8:57pm
333
Adding a solder blob is what I do to all my cells, no idea which cells come in button top.
30q, VTC5, vtc6, hg2 are all cells I have used with good results, none of them were button top though, I just solder blobbed the flat tops.
Sony VTC6 button tops are ideal if you can find any. Samsung 30Q button tops are a very close second best IMO.
richbuff
(richbuff)
July 7, 2021, 1:27am
335
I got 16 Sony VTC6 button top 18650 from Adventure Sport Flashlights for my two BLF GT94. They currently show on the website.
I’ve got 22pc of the VTC6 left. Both the vtc6 and the 30q are listed on my new website Lumencraft.com .
Fedtro
(Fedtro)
August 1, 2021, 8:02am
337
[quote=RamBull]
Quali batterie consigliate di usare nel GT94? Ho provato a utilizzare il Molicel 18650 P26A senza successo.
[/quote]
I use Molicel P26A with a welded head, do it too, it's quick and easy.
vit55
(vit55)
August 1, 2021, 5:36pm
338
Molicel P26A button top !!!
